Why are the exhaust ports "siamesed"?
Old Jul 25, 2002 | 06:48 PM
rskrause's Avatar
Moderator
Post Why are the exhaust ports "siamesed"?
Why are the exhaust ports on SBC heads "siamesed" instead of evenly spaced? No contemporary design head is made this way, so obviously there must have been some percieved advantage "way back then" that has since been debunked. Anyone know what it was?
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Old Jul 25, 2002 | 08:44 PM
Soma07's Avatar
Post
I "heard" it was beacuse back in the 50's when the original SBC was on the drawing board they wanted all 8 intake ports as close to the center of the motor as possible. This would help ensure each cylinder gets the same amout of fuel because the carb's of the day did not atomize fuel as well a more modern piece.
Keep in mind this is just theory I heard at one time. I dont know for sure if its right but it does make sense.
Jason
93 TA, M6
Old Jul 25, 2002 | 10:43 PM
ElkyRacer's Avatar
Post
Thats why I wouldnt mind seeing some of Brodix's IMCA Modified SBC heads on a LT1 car. They have the evenly spaced ports just like the LS1 heads. Headers and intake would be a pain to fab up tho. 320cfm out of the box would be worth it. And ppl would be like, is that a Ford in there? Thats the only downside.
Kyle
Kyle aka Shaggy
Purple 95 Formula
ETFA
12.00@116
Old Jul 26, 2002 | 07:23 AM
Eric Bryant's Avatar
Post
Back in the carb days, the spacing of the intake ports allowed a relatively even path length from the carb to the port. If you do symmetrical ports, it's much more difficult to get a straight shot from the carb to the port with a low-height manifold.
The "mirror-image" SB2 NASCAR head eventually came along 40 years later and addresses this problem. GM had a symmetrical port head for IMSA racing, but they didn't work well with the single 4bbl carb required in stock car racing.
1996 Impala SS - LT4 396, T56
1996 GMC K2500
1992 Buick Roadmaster Estate Wagon
Old Jul 26, 2002 | 11:05 PM
Stephen 87 IROC's Avatar
Post
Could be worse. I saw an old Ford flathead V8 where the 2 center cylinders shared the same exhaust port. A V8 engine with 3 exhaust tubes on each side.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
Old Jul 26, 2002 | 11:08 PM
rskrause's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by Eric Bryant:
</font>
Thanks for explaining that!
Rich Krause
"1FASTZ28"
TitoPR221
May 26, 2015 12:20 AM
Drtryder
Apr 22, 2015 04:17 PM
thenewkid
Apr 12, 2015 07:42 PM
MadMav
Feb 6, 2015 11:02 PM
