what is the trick to seating the tranny pump?
Old Aug 24, 2002 | 06:38 PM
john-e-boy's Avatar
Post what is the trick to seating the tranny pump?
I am finishing up a rebuild on my 700R4 and I am stuck on installing the tranny pump, I can get it all the way down to the pump seal and then it doesn't seem to want to go anymore. Is it supposed to be hard to install or should it just slip right in? I have had it in and out three times (had to replace the shaft seals after the first time)and all times it only gets so far.
Any help is appreciated
John
Old Aug 24, 2002 | 06:51 PM
Brad 97z's Avatar
Post
It should go all the way and then have maybe 1/2 to 3/4 inch more to go in. If that's what your talking about just thread the bolts in and use them to pull the pump in. Once you get done make sure that the input shaft turns(it will only turn in one direction and it will be hard to turn) if it doesn't you misplaced something causing the clutch packs to compress.
Old Aug 25, 2002 | 12:30 AM
OneFlyn95z28's Avatar
Lightbulb
OUCH Brad!
See other post
If you use the bolts you will not feel if you cut the rings
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Snoman73
Nov 17, 2014 07:22 PM
Timberwolf
Jul 30, 2002 08:31 PM
