At what point do 4 bolt mains become necessary?
Old Dec 28, 2003 | 11:40 AM
  #31
OBDIICamaro's Avatar
How is a Splayed cap put in? Is it a Straight Bolt or is it on a angle like the LS1? Just curious I dont think I have ever seen one.
Old Dec 28, 2003 | 02:34 PM
  #32
rskrause's Avatar
Moderator
Splayed = outer bolts at an angle.
Rich Krause
Old Dec 29, 2003 | 11:31 AM
  #33
onebad96T/A's Avatar
I have never heard of someone that i know or read on cz28 that they have broken a main cap or pulled the caps off the block or any kind of main cap failure. But remeber this, it does not matter if you have 10 bolt mains you still can spin main bearings and that is what i hear are the most problems with LT1/4's are spun bearings. But the added strength of 4 bolt main caps caint hurt. If your are running a big shot or high boost i would not think twice because of the added cylider pressure against the piston, rods and crank. Just for an N/A motor stay with the 2 bolt mains. Just my .02 cents
Old Dec 29, 2003 | 01:13 PM
  #34
rskrause's Avatar
Moderator
That isn't what happens. The main caps can distort under pressure and this is one of the cuases of bearing failure.
Rich Krause
Old Dec 29, 2003 | 01:40 PM
  #35
Rich Krause
What precautions can you take to keep from bearing faliure? 4 bolt caps or 6 bolt caps, proper oiling system? I know other failures can cause bearing failure but just the wear and tear on bearings, a splayed cap dont prevent main bearing failure. I see bearing failures all the time with any main cap set ups 4 or 6. I think there is alot of people think if they have splayed caps the bottom end is bullit proof and they are not, but thet do help for distortion and distortion is only 1 cause of bearing failure.
And i agree with you that caps can distort under pressure and can cause bearing failure.
Old Dec 29, 2003 | 01:42 PM
  #36
Gripenfelter's Avatar
Just FYI.
There are guys in my town running 2 bolt mains on 600hp iron block mills with no problems. The emphasis is usually on stronger 4340 steel cranks.
They don't recommend 4 bolt splayed mains unless you're using juice or forced induction.
Personally I would do 4 bolt mains on anything over 500hp as stated above.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Mar 13, 2015 11:48 AM
pimpss96
Feb 12, 2015 01:28 PM
97 RedSS
Jun 10, 2003 07:58 PM
