What does an average cammed, wild cammed L1 idle at, and see at WOT (in kPa)
Old Jan 25, 2003 | 05:42 PM
LTOne4Fun's Avatar
Looking where to play with the idle and WOT timingg tables
Old Jan 26, 2003 | 12:08 PM
Brandy's Avatar
If you mean LT1 mine idles fine at 850 but I have a pretty big converter. With a stock converter I had to idle it at 1,000. My cam is a 236/248@.050.
Old Jan 26, 2003 | 12:56 PM
LTOne4Fun's Avatar
I menat in kPa (see subject) not rpm. I want to see where i the timing maps idel is
Old Jan 26, 2003 | 01:18 PM
OneFlyn95z28's Avatar
I get 50ish at idle and usually hit 101 at WOT
small 234/242 on 112lsa
Old Jan 26, 2003 | 03:02 PM
Is it "average cammed" or "wild cammed"? An "average cammed" engine is not likely to be a whole lot different than a stock LT1, or MAP about 1/3 of the barometric pressure where you live. A "wild cammed" setup will more likely see MAP in the range of 50-60% of barometric.
At WOT, the MAP should be as close to barometric pressure as possible, no matter what kind of cam.... hopefully no more than 1-1.5"Hg (3-5 kPa) below barometric.
And remember, barometric pressure a sea level, on a "standard" day will be around 103 kPa, and in Denver will be dropping down into the high 8X kPa range.
Old Jan 26, 2003 | 03:25 PM
Dr.Mudge's Avatar
Most cars will idle around 35-65 MAP I'd say, with a little bounce for the more cammed the car will be.
As for WOT I think the most I ever saw was 104 or 105 but I dont recall, and unfortunately didn't save most of my logs POST dyno tune, oops.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
alex5366
Feb 17, 2015 08:12 PM
rje
Sep 9, 2002 12:35 PM
