WHat is clearancing?
Old May 3, 2005 | 08:11 PM
Heatmaker's Avatar
Advanced Member
What exactly is done in the process of clearancing?
I plan on using Manley 4340 rods... on a 383 setup... should I have any issues with my 236/24X cam?
Old May 3, 2005 | 08:14 PM
12Second3rdgen's Avatar
Re: WHat is clearancing?
Are you asking about clearancing in general or just rod to camshaft clearance?
Old May 3, 2005 | 08:28 PM
MachinistOne's Avatar
Manley rods are pretty good with clearing the cam, the block will need to be clearanced though, basically you mock-up the motor with the crank in place, start putting in piston/rod assemblys and rotating them, mark the spots where they hit at the bottom of the bore and on the pan rail, the break out the die grinder. I like to see a minimum of .080" clearance between rotating parts.
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Sep 15, 2015 11:07 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
Aug 5, 2015 08:35 AM
