The weirdest sound coming from the front of my LT1..please listen and post ideas.
Originally posted by Hot Rod Hawk
I belive the pocket on the opti that the cam dowel pin recives into is .320 deep and the dowel should be around .285 long. Yours look much longer in the pics. New CAM?
If the dowels to long it will cause excessive pressure on the opti.
Hows the opti spin in your hand?
Bearing feel ok?
Theres three areas on the retainer that show up as not normal to me under the left bolt on the 2nd picture. Was the cam gear seated properly on the cam?
could it have been cocked?
Just questions bro, good luck.
Bearing feel ok?
here are some pics of the cam gear:
http://bellsouthpwp.net/x/x/xxsaint69x/camgear2.JPG
http://bellsouthpwp.net/x/x/xxsaint69x/camgear.JPG
the camshaft end play spec for that motor is 0.004-0.012",
check it.
check it.
Marcin
if it has anything to do with pushing the cam all the way back and then out and checking the distance with the cam gear installed i have pretty much 0. I cant pull it out at all.
well i think we are onto something here...went and put the stock timing gear on the cam and sure enough i have little bit of play.
I have 0 play with the CLoyes gear. It take a tinny bit of effort to spin the cam with the cloyes gear on there, and it doesnt take any with the stocker. So whats next? What do i need to grind down? Or do i have to put a washer somewhere?
Marcin
Marcin
Originally posted by xxsaint69x
how do i go about checking it? I only have a dail caliper
Marcin
Marcin
.Sounds like the gear is out of tollarance to me. Be sure to sent them the pics with the three rub spots or point them to this thread.
Yes thats how to check it. I'd think you need to call the gear manufacture at this point and see what they say bro
well i called summit and they kept on telling me the chain i have 9-3145 is not for a LT1 and it wont fit without clearancing the block. I kept telling him that 1000s of people run that chain without any modifications (-waterpump) without any problems. He just kept telling me i need a single chain setup 3155 i think. Anyways, since they are being a pain in the ***, can i just grind down a tinny bit of the back of the gear to get some clearance?
thanks
thanks
thanks
Matt Swindel had the same problem as you with that same part number. He did what they said...3155
NO DO NOT GRIND THE GEAR
IMO, I wouldnt use a Cloyes timing chain if it were given to me. My engine builder has seen several of them break, and it makes a nice mess. On my motor, we went with a Rollmaster Billet true double roller chain. It is a fully machined billet steel gears with a german made chain if I remember correctly. The chain works great with the CSI waterpum, just might need a little more clearancing on the timing cover.
The part number for it is CP8305 or SBC chevy timing set w/factory hydraulic roller. Price is $79.95 from Competition Products in Wisconsin. I ordered it and had 2 days later. Their number is 1-800-233-0199 I have been running this chain for a while now, no problems and the chain is quiet as can be.
Dont put another cloyes in your car, or you will be asking for more problems than you have now. Anything else just pm me or reply back.
Brian
Brian
Brian
Brian
Hopefully no more noise for me
What you had to do is more common than people think. With varying tolerences on blocks, cam faces, and gears, this is the best way to gain the clearance that is required.
As far as Cloyes goes. I'm sure there have been some bad pieces put out by them, just like any manufacturer , but I haven't ever had a failure with thier stuff through the years and that's with cams in the .800+ lift range and 300lbs. seat pressure. They make parts for almost all the auto manufacturers and some of the aftermarket ones (Crane, Comp etc.)
My .02 pesos
My .02 pesos
car is back toghter...and the noise is still there... ITS THE OPTI MAKING IT FOR SURE....now i need to figure out why?
What can cause the bearing on the opti to go bad in matter of seconds? Or maybe i jsut got a defective opti??
pretty sure its not your opti bro, mine makes a similar noise & I really didn't care, on my buddies car we clearanced the timing cover & the noise went away, what you could try doing though is loosen the bolts on the opti & while under the car & the accessory belt off, try moving the opti in & out a bit see if the sound goes away, I'm positive its the chain hitting the timing cover though. Mine is been doing that noise for ages in all my cloyes LT1s, the car moves in & out just a tad which causes that sound.
As a matter of fact, the only car that I don't think is doing that noise with that chain is another buddie's 94 TA, but what I do remember though is his cam DOWEL was very long, we never shortened it & he's the only guy without the noise problem. So it makes sense that the car is being pushed back at all times so it can't walk up & hit the timing cover like mine can.
If you rev her up the noise does go away though because the cam tends to walk backwards with RPM.
