vavle lift: lobe vs rocker arm?
Old Jul 6, 2003 | 04:13 AM
mastrdrver's Avatar
Every time I see someone talking about getting more valve lift out of the cam I see all the engine builders say to get the desired valve lift grinded into the cam instead of using more rocker ratio. Why? I dont understand the difference. Is there an advantage to having in ground into the cam as to using the rocker arm make up the lift?
Jeremy
Old Jul 6, 2003 | 08:23 AM
PoorMan's Avatar
I have heard that also. Seems to me that if you let the rocker arm add to the lift then that is less wear on the lifters caused by the increased lift on the cam lobe.
Jeff D.
Old Jul 6, 2003 | 10:31 AM
kmook's Avatar
Advanced Tech Moderator
Read this thread:
http://web.camaross.com/forums/showt...threadid=37457
It gives alot of info about this.
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
LT14LIFE
Nov 15, 2015 06:22 PM
Z Power
Sep 19, 2015 11:19 PM
94Form
Jul 17, 2015 10:56 PM
