Trying to find compression ratio
Old Aug 24, 2004 | 03:09 PM
Briank8811's Avatar
What do i need to tell my mechanic if he wants to know the compression ratio. I know the pistons are keith black hypereutectic and the crank and rods are typical 383 parts. The heads and deck were plained and the bowls are stock on the heads. Do you need more specifics to find the CR? Thanks, Brian
If you can help me find this info then i can plug it into my compression ratio calculator.
Engine bore that has been 30 thousenths over
Engine stroke with the 383 rods
Deck height with 5 thousandths removed
Regular gasket thickness
stock cly. head (cc)
and its got flat top pistons
Old Aug 24, 2004 | 03:39 PM
rskrause's Avatar
Moderator
Re: Trying to find compression ratio
Making the following assumptions:
Bore 4.03 (inches)
Stroke 3.75 (inches)
Rod Length 5.7 (inches)
Cyl. Head Vol. 54 (cc)
Deck Height 0.020 (inches)
Head Gasket Bore 4.166 (inches)
Head Gasket Thickness 0.039 (inches)
Piston to Cyl. Wall Clearance 0.003 (inches)
Top Ring Land Height 0.25 (inches)
Piston Dome Vol. -6.2 (cc)
The compression ratio = 11.716:1
Rich
Old Aug 24, 2004 | 10:13 PM
Briank8811's Avatar
Was that the compression of my motor? I figured it to be at 9.75:1.
Old Aug 24, 2004 | 10:44 PM
Mindgame's Avatar
Show your work.
Maybe we can show you where you made your mistake. With a 383, the LT1's smallish chambers and flat-top pistons, the static comp is usually pretty high. Really need to know the specifics of your combination, like the actual piston volume, etc..
-Mindgame
Old Aug 25, 2004 | 05:58 AM
rskrause's Avatar
Moderator
I have no idea, my calculation was based on the little info you provided (stroke = 3.75", presumptive bore = 4.030", and the rest assumptions based on typical LT1 numbers. If you provide the actual values I can point you to a calculator.
Rich
Old Aug 25, 2004 | 01:24 PM
Briank8811's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33620
Those are the pistons in the car. The gaskets are fel-pro. The shop said the heads were plained and the block decked. The heads otherwise are stock with mild port work. The other stats should just be general, If not i will find them out to help me get an accurate CR reading.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
drptop70ss
Mar 26, 2015 01:50 AM
mattstrike
Mar 10, 2015 04:46 PM
blac94Z
Mar 6, 2015 07:55 AM
pimpss96
Feb 12, 2015 01:28 PM
