Tremec T-56 versions
Old Jul 13, 2002 | 11:09 AM
  #16
Post
Anybody know anything about the 6-speed that GM uses behind the 8.1L Vortec V8 (340hp/455ft-lb) and 6.6L Duramax diesel V8 (300hp/520ft-lb) engines in the Sierra and Silverado? It is described as a "ZF S6-650".
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Jul 13, 2002 | 06:32 PM
  #17
JordonMusser's Avatar
West South Central Moderator / Special Guest
Post
Jimlab-
More gear you will find helps you actually. if you try to tone down first with less gear(or start in 2nd) you will find that you will have to slip the clutch more, etc.
by having more gear, you can slip the clutch less, and/or launch(of racing) at a lower RPM.
4.10s and my 401ci motor was great.. even on street tires, I woulda switched to 4.56s if it weren't for the need to trap 140+ in 4th!
-94 Black T-Topped Z28 M6, 10s, and daily driven!
-96 CBR F3, modded of course
-92 Talon Tsi AWD, also too many mods..
-99 Tony Kart
http://www.fastblackcar.com
Old Jul 14, 2002 | 10:23 AM
  #18
nuke61's Avatar
Post
[iB]Anybody know anything about the 6-speed that GM uses behind the 8.1L Vortec V8 (340hp/455ft-lb) and 6.6L Duramax diesel V8 (300hp/520ft-lb) engines in the Sierra and Silverado?[/i]
Info found by searching the Internet:
It's a medium duty transmission. In contrast, the T-56 is a light duty transmission.
It was described as being able to easily handle the output of the high power/torque requirements of the new GM motors, and will be used in the medium duty truck line (Siverado is a light duty truck)
Gear ratios are:
5.79 3.30 2.10 1.31 1.00 0.72
Hear LT1 cam WAVs, DIY head porting: members.***.net/gmarengo
'95, !CAGS, CAI, ForceII, Hooker Shorties, 14.2@103
Old Jul 14, 2002 | 11:37 AM
  #19
Post
Killer first gear..... .
It's available on the Silverado 2500HD w/ 8.1L V8 or 6.6L diesel V8. These also come standard with 4.10 gears.... hmmm 23.7:1 overall.
Oh well, back to the drawing board.
Old Jul 14, 2002 | 11:52 AM
  #20
jimlab's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by JordonMusser:
4.10s and my 401ci motor was great.. even on street tires, I woulda switched to 4.56s if it weren't for the need to trap 140+ in 4th!</font>
I'm sure it is in the upper gears, Jordon, but I've got a ~2,700 lb. skateboard with a 2.97 1st gear (to your 2.66) and 550+ lb-ft. of torque. Since it wasn't built for drag racing, 1st gear is only going to be a tire shredder with anything but the most careful use of the throttle.
The car should have more than enough torque (quite a bit more at idle than the stock engine had even at peak) to start out in 2nd gear "normally". At 8.49:1 final drive (2.07:1), second gear is actually shorter than the McLaren F1's first gear final drive (7.65:1; 3.23 first gear, 2.37 differential), and my car is a hair lighter.
Old Jul 14, 2002 | 12:04 PM
  #21
kmook's Avatar
Advanced Tech Moderator
Post
</font>
Mind telling me how you trap 140+ in 4th with 4.10s?
Old Jul 14, 2002 | 01:41 PM
  #22
Soma07's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by kmook:
Mind telling me how you trap 140+ in 4th with 4.10s? </font>
A solid roller motor turning ~7,000rpm helps a bit. However that still leaves him a bit short so I suspect he's running a taller than stock tire. I bet a 28" ET street would get ya pretty close at 140mph@7k rpm.
Jason
93 TA, M6
Old Jul 14, 2002 | 10:31 PM
  #23
jimlab's Avatar
Post
I'll go out on a limb and state that I think that Jordon meant to say "130+". In the two drag racing videos he used to have on his web site, his trap speeds were in the low 130s.
Old Jul 15, 2002 | 07:17 AM
  #24
Eric Bryant's Avatar
Post
We don't have any of the big ZF trannies around work (at least not the last time that I checked), but we do have the NVG counterpart, the 5600. It's an iron case 6sp that weighs about 360 lbs (~200 more than the T56), and is about the size of a SBC block. There's no way it'd ever fit in a passenger car without huge amounts of floorpan work.
1996 Impala SS - LT4 396, T56
1996 GMC K2500
1992 Buick Roadmaster Estate Wagon
Old Jul 16, 2002 | 10:59 AM
  #25
Kraest's Avatar
Retired
Thumbs up
<font face="Verdana, Arial" size="2">Originally posted by jimlab:
I'll go out on a limb and state that I think that Jordon meant to say "130+". In the two drag racing videos he used to have on his web site, his trap speeds were in the low 130s. </font>
I think he meant 140s. Nitrous is a nasty thing on a 130 mph NA motor.
I've also had a great experience with D&D when I blew my countershaft in my T-5 with the Mustang. Ford wanted around $300 for their countershaft. D&D wanted $179 for theirs
Mike
<font face="Verdana, Arial" size="2">Originally posted by Green 96 T/A:
You guys make me laugh. How old are you all? Mike doesnt have any feelings. Calling him names will affect him about as much as running shoes would for a paraplegic's 100yd dash times... Know what I mean?</font>
1994 Sunset Orange Metallic Camaro Z28 Convertible - The Gorgeous and Sadistic Bitch Who Mistreats You and Lets You Down, Yet You Still Keep Her
1989 Red Ford Mustang LX 5.0 Convertible - The Dependable Girl Who Treats You Right, Yet Your Mind Wanders Elsewhere
Injuneer
Apr 25, 2022 06:22 PM
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
cmsmith
Sep 14, 2015 09:25 PM
