Top end fpr a serious 383/396
Old Feb 9, 2007 | 12:16 AM
  #46
mdacton's Avatar
yeah it oughta......If you build it, it will run.
Old Feb 9, 2007 | 05:54 AM
  #47
IllusionalTA's Avatar
my all pro's flow 370cfm give or take a few on a 4.030 bore, w/ a 2.15 valve.. could they go over 400 i'm sure.. but it's almost pointless on a small bore w/ the larger valve necessary to move that much air..
As far as affording all pro's vs. a 18* setup yea the heads were closely priced in parts and work to make them work.. but some like myself are stuck /w a 23* bottom end that already had a **** ton of $$$ in.. Not worth selling and starting over.. I figured i can get where i wanna go w/ what i wanted to spend on this head.. Think it's gonna be fun..
Old Feb 9, 2007 | 01:03 PM
  #48
TransAm396's Avatar
Originally Posted by Projectz28
The TFS heads had a desgin change about a year ago that corrected many issues. The newer desgin has TFS-SBC-8 cast into them. The older desgin has TFS-SBC-7 in them. The head is a completely new desgin and cast totaly different. Very nice head if you ask me. Plenty of material to port. My TEA ported TFS heads flowed 317cfm at .700" lift.
On a side note, I have dealt with AFR thru a friend of mine who is a dealer for them. Honestly if they are telling you 6-8 months you can bet you wont see a set of heads in your hands for at least a year! I opted the find another head and the TFS heads seem to be the best head on the market for an LT1 right now. I personally belive they are better than the AFR heads and I would highly recommend them over the AFR.
But if you have your heart set on AFR's you will still probably reach your goals... only it will be 6-8 months later
SBC-7s were a ****ty design??(those are what I have unfortunately)
Old Feb 9, 2007 | 04:30 PM
  #49
FASTFATBOY's Avatar
You truly think those heads will go 400 cfm or better, on a 4.030 bore at .700 lift or lower? 30 cfm is a HUGE..almost astronomical leap over what you have gotten already, over the porting pics I saw on here, that port was opened up a good bit over the way it came to you. I would love to get more thoughts on this.
David
Old Feb 9, 2007 | 04:44 PM
  #50
Projectz28's Avatar
Moderator
never said they were "****ty", just an older desging that has been improved upon with the release of the TFS-SBC-8 casting. I think the ports themselves are pretty close to the same with both castings.
Old Feb 9, 2007 | 05:54 PM
  #51
1racerdude's Avatar
You are soooo correct.
Them bad *** ones run about $5500.00 without conversion and rockers. Ya will have about $7000 in them.
Old Feb 9, 2007 | 09:44 PM
  #52
David
Yea they will go 400cfm.. maybe even on a 4.030 bore. but the quality of the air would probably be ****.. on a 4.1 bore or so.. they'd be pretty kick ***.. when i got them they moved 256cfm.. after a lil bit of work they moved 340.. even at that point if we were to stop they still would make great power.. We can't race flowbench's either.. that's been proven to hurt folk's feelings.... Ron's porting has a set that goes 380cfm.. that's on a cnc.. and if you really wanna go intricate ontop of that, i feel a knowledgeable guy can squeeze 400 out of them.
Old Feb 9, 2007 | 09:45 PM
  #53
well 1800 for the bare casting's about ______ in porting, and ______ in parts and stuff.. yea i can see 5K pretty easily lol... Oh well there it went..
Old Feb 9, 2007 | 09:47 PM
  #54
here's the post he's speaking of...
http://web.camaross.com/forums/showthread.php?t=436366
Old Feb 11, 2007 | 11:21 AM
  #55
FASTFATBOY's Avatar
Originally Posted by 95ttoplt1
Again I know I won't be the fastest "what ever" I just want to be faster than I am now, a nice 396 with a sweet Head Cam intake combo and a ****ton of nitous outta get it there.
The people who needed to read that post, did read it. Wasn't necessarily directed at you.
Making that power will kill the driveability of it, even at 650....daily driver status will be compromised. I would love to see other people ACTUALLY build more outer limit pumpgas LT1's.....instead of sit behind a keyboard and yap about it.
David
Old Feb 11, 2007 | 01:06 PM
  #56
I need more $$$ lol..
Old Feb 11, 2007 | 02:02 PM
  #57
Projectz28's Avatar
Moderator
dont we all
building a 1000hp daily driven LT1 is no problem if you got the cash
Old Feb 11, 2007 | 02:19 PM
  #58
dont we all
I'm going on 3yrs now doing the 800hp one lol.. all i have is time.. sure as hell ain't got any $$$ lol..
Old Feb 11, 2007 | 06:33 PM
  #59
FASTFATBOY's Avatar
Mine has went past 4 years, mostly because of a screwed up partnership that I did away with. The other partner just wanted to buy and pile up parts..never intended for it to run.
Mine will run this year for sure.
Yeh if we all had money we would all be driving limited street cars around with tags on em LMAO.
Old Feb 11, 2007 | 07:18 PM
  #60
96speed's Avatar
David
Nothing personal, but look who's talking. "10s on radials with the A/C blasting" used to be in your sig, 3 or four years ago. Secondly, this is Cz28.com, not LS1tech.com.
Ryan
