TEmp gauge drops when I give gas
Old Oct 17, 2020 | 01:33 AM
ALL-IN's Avatar
Temp gauge drop when in neutral or park and I give gas it will be at around 240 or the line before the red so it's running a little warm I'm not sure if both fans are kicking on but I just started to notice that the temperature gauge is dropping almost instantaneously with the speed gauge but I'm in Park or neutral or if I'm moving but if I'm just sitting still it just keeps rising but it never really gets all the way into the red if I turn my defrost heat on one fan will kick on ce it gets up past 240 any suggestions
Old Oct 17, 2020 | 09:04 AM
Re: TEmp gauge drops when I give gas
Please do not post the same topic more than once, on different forums.
https://www.camaroz28.com/forums/lt1...ve-gas-888571/
Please note also that this is not a correct topic for Advanced Tech. See “pinned” topics for guidelines on using Advanced Tech.
ALL-IN
Dec 10, 2020 01:46 PM
touch109
Aug 7, 2006 11:10 AM
Jerm982
Jul 24, 2004 01:50 PM
SDAKOVIC
Mar 1, 2003 02:40 PM
Trans AM 22502
Feb 18, 2003 07:43 PM
