Stock valve covers leaking on AFR 210's, help ASAP!
Old Jul 26, 2002 | 08:20 PM
BrianZ28's Avatar
Question Stock valve covers leaking on AFR 210's, help ASAP!
I just installed AFR 210 heads on my 396 stroker. When I put oil in it is leaking around the cover onto the ground. It kind of looks like the valve cover is to short, causing the corners from fitting down over the heads. Do I have to get aftermarket covers or something?
Old Jul 26, 2002 | 08:50 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Post
Stock valve covers will work with AFR heads.
The supports in the valve covers are probably hitting the rocker arms.
You will need to trim out the part of the support that is hitting.
Old Jul 26, 2002 | 11:15 PM
zturbo's Avatar
Post
A freind with a set of afr 220's had to use the lt4 valve convers (think they are a bit higher) I am running higher than stock alum ones myself
Steven
383 Inches of stroked turbocharged fun.
If one is good shouldnt 2 be great?????
TURBO=TORQUE
TORQUE=FUN
My Car
Old Jul 28, 2002 | 05:04 PM
LETHALRACER's Avatar
Post
I have 210s on my car with Trans Dap aluminum valve covers with no problem. I use a double thick Victor Reinz gasket. Good luck.
91 Z28 ALL FORGED 383,EAGLE 6" RODS,11.2:1 SRP PISTONS,TOTAL SEAL RINGS,MINI RAM,ACCEL 58mm T-BODY,AFR 210'S
int. exh.
.600 298.3 .600 261.4
COMP HYDRAULLIC ROLLER
236/242@.050 .555/.575, 950-16 SPRINGS 1.900in INSTAL,CRANE GOLD RACE 1.6 ROCKERS,CLOYES ROLLER CHAIN,MILODON OILING SYSTEM,HOOKER SPR COMP 1 3/4 FULL LENGTHS, 3"DUALS,X-PIPE, 4,000 VIGILANTE, 3.73,
BE COOL RAD,VIC jR. WATER PUMP,MARCH ALUM U/D PULLEYS,ACCEL 30lb INJECTORS,MSD DIG-6 AND WIRES,DUI DISTRIB AND COIL,TPIS LEVEL 5 PROM,SFI FLEX PLATE AND BALANCER,ADJUST FUEL PRESS REG,RAM AIR,EIBACK DRAG LAUNCH KIT,LAKEWOOK 70/30 F,50/50 R SHOCKS,NO EMISSIONS STUFF,NO A/C.
G-Tech time 12.20@124 w/200lb passanger.
Old Jul 28, 2002 | 06:17 PM
bowtiepwr's Avatar
Post
>I have AFR #1031 LT4 heads (195cc) and when I installed them with the stock LT1 valve covers they also leaked , so I installed some washers under the valve cover bolts , and that cinched them down , and now they do not leak ... later I will retap the holes .
Later ...
stay safe
Old Jul 28, 2002 | 06:55 PM
Kevin - Blown 95 TA's Avatar
Post
AFR taps all the holes shallow, front & back of the head, intake, and valve cover. I have the LT4 195 cc heads & LT4 valve covers (plastics) which use studs. I had to shorten them. I'm willing to bet your screws are bottoming out and not pulling the valve covers down. Also, I tried tapping deeper with an end tap, but there wasn't but one more thread and that wasn't enough. You should ensure that your intake bolts aren't bottoming out like mine did. I had it half glued on before I figured that out. I called AFR to tell them that they really should include a note with the heads warning us that all the holes are shallow, but I don't know if the guy cared or not.
HectorM52
Jul 30, 2017 11:46 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
