Solid Roller Lifter Opinions
Old Feb 12, 2008 | 12:27 PM
ulakovic22's Avatar
Hey guys, I need a few opinions before I pull the trigger on buying a set of lifters for my BBC. A lot of people make lifters and I wanted to hear from those who have run solid rollers what would be the best option. Popular companies out there (Comp, Isky, Lunati, Crane, Jesel) offer pressurized oiling, but wanted to hear from those who actually run them what they have had success with.
Thanks,
Anthony
Old Feb 12, 2008 | 01:54 PM
rskrause's Avatar
Moderator
Thanks,
Anthony
I use Crowers, but I wouldn't put any of them on a street car.
Rich
Old Feb 12, 2008 | 02:46 PM
ulakovic22's Avatar
It's not going to be a street car per se. The car will be driven on the street to go show it off or something but not driven in traffic or even on the weekends, just like once a month. The car will 98% of the time be a drag car mainly running the 1/8 up in Denton and I might take it out to Ennis if I can snag my brothers truck/trailer.
Is the only concern with 'street' solid rollers the low RPM oiling? If so what is considered low?
Old Feb 12, 2008 | 03:19 PM
P's Avatar
P
I have Crane 11522's, and so far they have been great, no issues. I would like to put a set of Isky's or Crowers in with the HIPPO set up. I don't think my Cranes have that. If you had the extra $$$ there is a company called Schubeck that makes awesome lifters.
P
Old Feb 12, 2008 | 03:25 PM
rskrause's Avatar
Moderator
Crower then. Call them - there are three different types (plus a number of variations) last I looked. They can advise you which to get AFAIK they are still made in the US. I have a set of standard duty with almost no time on them if you are interested. I ended up going with the "Ford" diameter because my lifter bores needed to be honed.
Rich
Old Feb 12, 2008 | 03:38 PM
ulakovic22's Avatar
Ford diameter being .874 instead of .842? Let me check out the Crower's. I'll send a PM.
Old Feb 12, 2008 | 03:58 PM
Crower cutaways..... on a car that saw the street for a couple years, with no problems.
Old Feb 12, 2008 | 05:03 PM
ulakovic22's Avatar
Thanks guys, called Crower and they said I would need to run the 66293 Cutaway lifters with the raised link bar because I'm retro fitting a Gen V block from tappet to roller.
Old Feb 12, 2008 | 05:14 PM
mdacton's Avatar
Your not going to run it on the street are you?
I have isky red zones.......I like them. Crane ultra pros are nice too. IMO anything from crower is good, I would run those too
Old Feb 12, 2008 | 05:17 PM
ulakovic22's Avatar
No it's not going to be on the street.......very often.
Old Feb 12, 2008 | 05:21 PM
mdacton's Avatar
I think idling alot and driving in traffic is what kills them, but I know some people that drive them all the time and never had an issue.
Look into getting good oil.
I'm getting the Brad penn oil from now on in my race car from the fuel place locally and wix filters
And I got one of those filter cutters so I can cut it open every time to check it out
Old Feb 12, 2008 | 08:41 PM
MachinistOne's Avatar
Isky, Crower, and Crane are all good lifters. We have quite a few dual purpose motors out there with Crane solid rollers and their link-bar lifters. We use the Isky and Crowers on the road race motors because they have good options for off-sets and come ready for rev-kits.
Old Feb 12, 2008 | 09:51 PM
FASTFATBOY's Avatar
I got the Comp Endurex with 3000 HARD miles, street/strip....are doing well. BUT I have my car idleing in gear at 1150rpms and holds 40 psi of oil pressure hot in traffic. I use Shell Rotella 15-40 oil.
David
Old Feb 12, 2008 | 10:30 PM
mdacton's Avatar
David
I have 40 at idle too, I am using 5-30 now. just for refrence
Old Feb 12, 2008 | 11:13 PM
P's Avatar
P
I've got about 5,500 miles on mine and use Valvoline VR1 20w50, I give it hell on the street on nice days when I have time to take it out and have driven it multiple times 2+ hours on road trips or trips to the track. Still goin strong. Idle @ 180* is about 25~30psi. 2krpm+ is 60psi+.
P
