Sheet Metal Intake under 7000 RPM's
Old Apr 3, 2006 | 04:48 AM
  #16
SABLT194's Avatar
Re: Sheet Metal Intake under 7000 RPM's
Steve,
I have been trying to get ahold of you for the last couple weeks...you must have changed your number! Give me a ring when you have a second.
On the intake note...for this RPM range, you can fill the bill with a properly designed single plane. I have been contacted by 2 different people in the last couple months about providing machined manifolds for "bolt on" kits, The only problem I currently have is making everything fit under a stock hood...maybe you wanna be a guinea pig...
Dennis
Dennis,
I PM'd you my cell number. I'm not adversed to running speed density, as a matter of fact I already have a SD tune somewhere. Also, Will a 4" cowl hood make everything way easy? I would consider that also if there's substantial power to be had. I may have also found some more problems on my car. Looks like the opti terminals and harness are crappy and giving me an intermittant miss at most RPM's. New parts on the way and crossing my fingers for about 20 more ft-lbs of missing torque.
Steve
LeftoverChinese
Jan 14, 2024 03:03 PM
squarehead
Nov 21, 2014 08:02 PM
Jim S. '95 Z28
Jul 25, 2002 11:58 AM
