SCAT 350 crank (9000)
Old Mar 15, 2004 | 09:00 PM
AHARTZ28's Avatar
anyone running the SCAT 350 9000 series crank? i ran the 383 crank in mine it was a great cranka nd esy to balance. i spun a bearing and was planning on going 355 or 360 with the scat 9000
thanks Ryan
Old Mar 16, 2004 | 01:37 AM
SStrokerAce's Avatar
For $250 you can pick up a new Scat 9000 383 crank. They are great for street cars and can handle a good amount of power too.
Bret
Old Mar 16, 2004 | 05:05 AM
SABLT194's Avatar
Will these cast cranks be reliable under the following conditions:
355 CID putting down 405 ish RWHP - 306 cam - Phils heads
Internal Balance- 2 bolt main block
I beam Rods
KB light pistons
Shift RPM 6700 in an M6, PCM limited at 6800 - Launch at 5000 RPM
Bracket race 10 passes per weekend every weekend of the season.
Old Mar 16, 2004 | 06:47 AM
AHARTZ28's Avatar
I beam Rods
KB light pistons
the 383 i built with the scat crank is great as well, lloks like the 350 one is good as well. i was looking at TRW forged pistons eagle rods witht it as well
thanks
drptop70ss
Mar 26, 2015 01:50 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
Chevyguy358
Jan 28, 2015 08:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
