sbc spark plugs - gap, hotter, colder. help
Old Apr 20, 2003 | 01:49 PM
menlatin's Avatar
OK, got a 355 sbc ported heads (284/237), comp nx274 hyd flat tap, 10.3:1 with domes, all forged bottom end. right now imusing autolite 24's with a .040 gap. I tried .045 and the plugs were fowling kind of easily, so i thought maybe .040 would be better. Well, i've got an accel coil and distributer and it sounded like i overreved @ 5900 RPM. Now that should not be happening with my heads and that cam is rated 2500-6500. Is that .040 gap too small or too big, and coiuld it be that my plugs aren't cold enough or too cold. they're 2 steps colder than stock.
Old Apr 20, 2003 | 02:13 PM
If you are getting fouling of the plugs, they are either too cold, the mixture is too rich or the ignition is weak and misfires are leaving you with a lot of unburned fuel. Since it doesn't seem to want to rev over 5,900rpm, sounds like the ignition system is weak, or the tune is way too rich. Two steps colder than stock shouldn't be a problem, unless the tune is off. Carb or EFI?
Old Apr 20, 2003 | 02:33 PM
menlatin's Avatar
i think my coil is like 45,000 volts, and it was running a little but rich. but what about that gap? is .040 enough?
Old Apr 20, 2003 | 02:49 PM
Mindgame's Avatar
Pull a plug and let us know what it looks like. A good hi-res photo would be even better.
.040 is fine and I agree it's either rich or you have low spark intensity. And knowing whether carb or efi would help with the route for your fix.
Are you sure there's no oil fouling???
-Mindgame
Old Apr 20, 2003 | 02:59 PM
menlatin's Avatar
oh sorry, its a carb, 750 speed demon. the plugs looked completely black, so its really rich. i cut the fuel back alittle when it started missing, and that stopped it. i guess its just rich then.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
