SBC in a '94
SBC in a '94
I am about done with my car, WE are about done putting a 383 sbc in a 94 Z28. WE have found that the bolt pattern on lt-1 heads is the opposite of standard sbc heads (front and rear patterns are swapped) So, my accessory brackets won't work. I'm told v-6 brackets will work. If anyone has done this, where did you put the AC compressor? Any help would be appreciated.
Re: SBC in a '94
Well, I'm going to be driving it daily for about the next 2 years. When i decide to just race it, i'll get rid of the sbc and the AC at the same time for an alloy BBC.
Re: SBC in a '94
Check with Street & Performance http://www.hotrodlane.cc/
I don't know if the V6 bracket will work but you could easily pick one up at the local wrecking yard. That or at least make a quick test template.
Good luck.
-Mindgame
Good luck.
-Mindgame
Bryan 94 Z28
Advanced Tech
Oct 8, 2002 11:46 PM
