Rod and piston Help ?
Old May 18, 2005 | 08:14 PM
67RSSS6SPD's Avatar
I looking at using eagle SIR rods (bushed) with Mahle forged piston with negative 5cc (.03 over)and Clevite H series bearings,and a Melling stanard volume oil pump.
Does this look like a worth wild set up for the bottom end.Thanks
Old May 18, 2005 | 08:32 PM
SStrokerAce's Avatar
Re: Rod and piston Help ?
Yeah, that's what I would do but I probably recomended it!
If you are going NA or a small N2O shot for a 355 you are golden... I was just talking with OldSStroker about a Joe Sherman 347 Ford that was very similar... Really good pistons with some inexpensive forged I beam rods.
The bearings and Melling pump will work out awesome.
Bret
Old May 18, 2005 | 08:37 PM
67RSSS6SPD's Avatar
Yes NA and maybe a small shot,with a le2 set up.Are the stock pistons neg 4cc.
(thanks bret.)
Old May 18, 2005 | 10:33 PM
The stock ones I think are in the -6cc range. The Mahle's are -5cc, but you should also deck the block so that will help with the quench and compression ratio.
Bret
Old May 19, 2005 | 01:56 AM
racer7088's Avatar
Thumbs up Re: Rod and piston Help ?
Are you at stock stroke?
Old May 20, 2005 | 04:18 PM
67RSSS6SPD's Avatar
Yes it will be at zero deck and 5.7 rods.Stock crank.
What are the gains if I went with 6" rods over the 5.7 rods?
Old May 20, 2005 | 05:02 PM
Lighter parts.... you will stress the crank less since the pistons will have less mass. It will also help if you have a head port that is too small for the application.
Bret
Old May 21, 2005 | 03:32 PM
Mindgame's Avatar
Bret
Exactly.
Don't worry about the .300 longer rod... the real advantage comes from a lighter piston. FWIW, the Manley I-beams (similar to SIR's) are about 20 grams lighter.
-Mindgame
Old May 21, 2005 | 05:07 PM
LameRandomName's Avatar
It just so happens that I have a Mahle powerpack set for sale, for 6" rods. Brand new, open box.
$500 and I pay the shipping.
Look it up on summit: SBC250040FT
Old May 21, 2005 | 08:10 PM
67RSSS6SPD's Avatar
Mindgame thanks for the info on the Manley I-beams I will look into them.
Thanks for the offer on the pistons but I would rather not use 6" rods.
Old May 21, 2005 | 08:23 PM
67RSSS6SPD's Avatar
Originally Posted by Mindgame
Exactly.
-Mindgame
Dam more than I'm looking to spend,I'm also looking at the scat I-beam rods the are close in price to the eagle's.I wounder which ones are better for mt set-up.(355/5.7rods/stock crank/zero deck/blanced/LE2/NA)
Old Oct 1, 2005 | 10:47 AM
jz3082's Avatar
i got 5.7" SIR rods and i'm going with the le2 setup. If i go with srp pistons 138081 will that compression be too much. I think the le2 heads are 55cc so that might be around 11.5:1. Also i was looking at mahle pistons but i cant seem to find one that will have a similar compression ratio.
Old Oct 1, 2005 | 09:04 PM
1racerdude's Avatar
Get a set of 4 eyebrow flattops,"0" deck the block, open the combustion chambers to 56CC's,with the Fel Pro .039 gasket if ya are running stock stroke. According to your cam ya should be fine.If ya run a larger size cam ya may be able to skip the combustion chamber enlargment.
If ya are running a 383 stroker the 5CC dish is OK.Again that depends on the cam.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
