rocker arm ratio
Old Jun 7, 2005 | 02:28 PM
  #16
J'S Z's Avatar
Re: rocker arm ratio
Well I will be useing Jesel shaft mounted rockers to go with the 18*heads.If that makes a difference.
Old Jun 7, 2005 | 08:11 PM
  #17
Dave69Z's Avatar
Originally Posted by INTMD8
What I find interesting is the amount of difference between rocker arm manufacturers. (how the rockers are built), and their effect on geometry and horsepower.
If you've ever checked geometry with a few different brands on the same engine, than dynoed them, you would be suprised.
What were the results of your testing? Who's rockers worked well compared against who's rockers?
Dave
Old Jun 8, 2005 | 12:04 AM
  #18
SStrokerAce's Avatar
I got into it with the Crane guy on LS1tech about those things....
Basically they just lower the pushrod mounting point on the pushrod side of the rocker.... makes a different path for the roller to sweep on the valve and a "faster" opening... I guess, not a huge fan of them, BUT on a small cam motor they would work really well.
Bret
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
JCSWS6
Jul 19, 2015 06:47 PM
94Form
Jul 17, 2015 10:56 PM
