Limits of the stock LT1 intake
Old Sep 29, 2007 | 03:39 AM
sleeperz28's Avatar
does anyone know the point(if it exists) at which this intake will not flow enough air to support a power level at a particular rpm?
Im probably making close to 1400-1500hp to the crank with it. I know the back 2 plugs dont get enough air. Thought about going to a dual plan intake. Just wanted to get some thoughts before i did
thanks
Old Sep 29, 2007 | 04:15 AM
GRNcamaro's Avatar
not that i know any thing about a 1500hp car but u look at the edelbrok lt1 intake manifold
Old Sep 29, 2007 | 09:05 AM
96capricemgr's Avatar
thanks
I know a guy making similar power with a modded LT1 intake, he found a lot of power in setting up a multiple wideband system and balancing the cylinders individually with programming. Granted he did not get more air anywhere he just got the air and fuel balanced.
Old Sep 29, 2007 | 10:42 AM
At those power levels, the issue is going to be plenum volume. Simply raising the roof would help. I think someone was offering that service (Jordan Musser????). Might try a "search".
Not sure how that would provide any significant gains, since the Edelbrock appears to be a straight copy of the stock LT1 intake, with a bit of the lower section cut away for the "air gap".
Old Sep 29, 2007 | 01:27 PM
sleeperz28's Avatar
My buddy went with a victor jr style intake and put a hat on it. Its equal distrabution which looks good. I might go with that. Seems to be the style of intake a lot of turbo guys use.
Old Oct 7, 2007 | 01:39 AM
marshall93z's Avatar
Off topic, but what transmission you running?
Old Oct 7, 2007 | 10:36 AM
The answer is in this thread..... the engine now appears to be in the 1300-1400rwHP range.
http://web.camaross.com/forums/showthread.php?t=544653
Old Oct 7, 2007 | 12:07 PM
RRR's Avatar
RRR
raise the roof! I honestly think switching to a super vic single plane setup would be best and you should see a sizeable gain across the rpm range with that setup over any modified lt1 "breadbox" intake - there is only so much you can do with it.
I would be interested if anyone knows the person(s) who were "raising the roof" lol on the stockers or approximate cost to have it done at a machine shop.
Old Oct 7, 2007 | 02:48 PM
Thanks Fred.
Old Oct 7, 2007 | 04:14 PM
sleeperz28's Avatar
My buddy just did a victor jr setup. Ill see how that works. If good ill probably do that
oldschool
Feb 9, 2016 09:21 PM
Catmaigne
Dec 25, 2014 12:16 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
thenewkid
Nov 27, 2014 09:41 AM
