Quench on big bore small blocks
Old Nov 27, 2005 | 04:20 AM
SABLT194's Avatar
Do the same quench rules apply on big bore (4.125 or 4.25) small blocks. Seems the good number is about .040 ish for std bore. Also, can you still get away with 12:1 and 9:1 DCR on the big SBC motors with traditional cooled aluminum heads,93 pump gas, and EFI of course?
Old Nov 27, 2005 | 10:03 AM
Mindgame's Avatar
Re: Quench on big bore small blocks
Yes, same rules for quench apply.
I am running 8.8:1 DCR in a 457 ci small block right now and the engine is very happy. This engine will never turn enough rpm (peaks at 7300) to ever have issues with flame speeds in its 4.2" bore.
You should take a few precautions though if you want to push the 9.0 mark. In my engine, I had Swain coat the combustion chambers, exhaust & intake valves along with the exhaust port. If anything, I'd always at least polish the combustion chambers, coat the exhaust valves with the exhaust port and make sure there are no sharp edges on the pistons.
If you decide to go with a head that has optional cooling to the center exhaust port pairs... take advantage of that. The sb2.2 and many splayed heads cool much better in that area so they don't need it.
-Mindgame
rojo10956
Classic Engine Tech
Dec 13, 2021 12:17 PM
dpw21562
Apr 16, 2015 09:41 AM
ad356
Apr 11, 2015 08:49 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Perry93TransAm
Aug 20, 2002 11:23 PM
