Pushrod length using Morel Lifters...
Old Oct 17, 2005 | 06:06 PM
RedLT4Mike's Avatar
Well, now that I've ruled out using Comp R's in my new stroker
I'm going to buy a set of Morel's.
My Question is.... Will they affect pushrod length requirements?
Aren't they slightly diffrent in dimension compared to a stock lifter
Old Oct 17, 2005 | 08:08 PM
rskrause's Avatar
Moderator
Re: Pushrod length using Morel Lifters...
PR length has to be measured when you make changes to the valve train.
Rich
Old Oct 17, 2005 | 09:04 PM
SStrokerAce's Avatar
I haven't checked how much they change that yet.... still going to drop a set of R's in a motor and then compare the length to Morels. I'm expecting the Morels to be longer.
Bret
Old Oct 18, 2005 | 08:07 AM
LT4POWR's Avatar
Bret
Yes, the Morels were/are longer, but I didn't measure how much.
Old Oct 18, 2005 | 11:14 AM
NJLT1SS's Avatar
The body of the Morels are longer compared to the R's I was using, but that was mostly at the top of the body at/above the lifter hold downs. The lifter plunger location appeared to be close side by side, but I switched rockers as well, and ended up with a different pushrod lenght all together. Regardless, pushrod lenght has to be checked.
Nick
Old Oct 19, 2005 | 11:30 AM
aggiez28's Avatar
advanced tech?
best bet is to measure to see the lenght you need
brook
Old Oct 23, 2005 | 03:31 AM
RedLT4Mike's Avatar
I will be checking the length...
Maybe the question should have been...
What is your experience with Morels and pushrod length?
Thanks for the responses!
Old Oct 26, 2005 | 07:31 PM
I did a check the other day and the PR length was .100 longer with the Morels over the Stock/OEM style lifters in the shop. (7.300 vs. 7.200) This is with .030 preload on the Morels and zero on the stock lifters.
Bret
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
