Piston to valve ?
Old Dec 9, 2002 | 08:21 PM
Schurters LT1's Avatar
Piston to valve ?
On a stock bottom end car what is the max lift and max dur before you will run in to problems? i am putting in a solid roller cam this winter and i don,t want the piston and valve getting to know each other?
thx
Old Dec 9, 2002 | 08:49 PM
rskrause's Avatar
Moderator
It's not just lift, it's the valve timing as well. Other factors play a role, such as any head milling, the deck height, gaskets used, etc. So unless you are sure your combo is the same as someone else's you can't assume that a cam (and it must be the same also) that worked for them will work for you. You need to measure piston-valve clearance.
Rich Krause
Old Dec 9, 2002 | 09:22 PM
OK let,s put it this why is there any one running over 610lift and more then 250dur on a stock block and heads
this is a heads and cam combo i am going for over 400rwhp :D :D
Old Dec 9, 2002 | 09:29 PM
97 RedSS's Avatar
Bigger isn't always better..Duration plays a huge part also..
Cody
Old Dec 9, 2002 | 09:34 PM
my cam will be under those spec so what i am trying to find out is am i safe or sould i ck the pistion to valve cl?
thx
Old Dec 9, 2002 | 09:39 PM
LTOne4Fun's Avatar
Check it
94Form
Jul 17, 2015 10:56 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
