which piston??
Old May 14, 2003 | 04:36 PM
gixXxinRS's Avatar
which piston??
iv been looking at some post about building a 383..
and have run across something.. which should i go with..
.a Hypereutectic piston w/ the head and piston ceramic coatings
or a forged set w/ the exhaust valve and port coated??
any info would be helpful
tia,
Old May 14, 2003 | 04:47 PM
gixXxinRS's Avatar
sorry, it a
383 w/ a scat 9000 w/ 6" rods 10.5-12:1CR
set of bare AFR 220s,1.6 RR
looking for 420+HP
on a th350 w/ a 3200-3500 stall
Old May 14, 2003 | 06:30 PM
99huggerorangeZ's Avatar
go with a set of forged piston and i would also go with forged rods and crank
when i built my 383 i went with JE pistons (10.3:1) and 6.0" Eagle rods with a Eagle 4340 forged 3.750 stroke crank
it is a stout short block costing me $3000
Old May 14, 2003 | 06:41 PM
Jerm93z28's Avatar
$3,000 shortblock, victor jr. heads, rpm airgap intake....
my question is..... why did you put a hotcam in there???
jeremy
Old May 14, 2003 | 11:12 PM
Question
why not??
Old May 14, 2003 | 11:49 PM
Jerm93z28's Avatar
well, im just wondering why you spent $3,000 on a shortblock thats good for 2x the power your making....
thats an expensive motor to only make ~400rwhp.
are you planning alot of nitrous in the future?
jeremy
Old May 15, 2003 | 10:56 PM
dude 450-500hp can take about anyone on the street and not to mention i have close to 500ft lbs of torque
Old May 19, 2003 | 03:47 AM
TheNovaMan's Avatar
gixXxinRS, go with the forged pistons. To get 420 HP out of a 383 you shouldn't need coatings (unless maybe you plan on huge amounts of nitrous). Put that money into a good cam/intake combination.
Old May 21, 2003 | 09:31 AM
Fire95Z28's Avatar
afr 220
The AFR 220 I think are maybe just a little bit of overkill.What are you planning to do with this just strictly out on the strip cause when I talked to them I am doin an 800 horse blower/stroker they told me anything bbigger than 195cc was overkill.
Old May 21, 2003 | 10:50 AM
Jerm93z28's Avatar
Re: afr 220
the afr 220's would be good for a n/a 383 turning alot of rpm's. basically a race motor, like you said. when i say alot of rpms i mean shifting around 7k or higher.
jeremy
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
