Easiest/Best Tools for Polishing Combustion Chambers
What the Easiest/Best way to polish the combustions chambers....
Please post a link or picture of the tool you used as well.....
Im thinking of trying flap wheels, and carbide burrs to "unshroud" the valves......
Heres the DIE GRINDER im buying: Die Grinder 25,000 RPM
What do you guys think of that??
Cutters to unshroud the exhaust valve and then I use the large flapwheels going from 60-80-120 grit. The flapwheels are the most used thing in my shop besides cutting bit when it comes to porting/polishing. I actually pulled the heads after the engine had a few hundred miles on it and checked the swirl pattern and noticed the intake side was experiencing wash, so I dimpled that area to produce some atomization and it's got a ncie clean burn all around. Something else to consider since you want swirl in the combustion chamber
-Shannon
-Shannon
Nayr
03-03-2023 08:34 PM
RX Speed Works
07-24-2015 02:25 PM
