Oil problem?
Old Jun 21, 2006 | 10:44 PM
GoFast908Z's Avatar
Member
Exclamation Oil problem?
Mod: i posted in the other section, and had no help. It has also stumped several shops....
So, i'm running at 250 degrees (engine oil) lately, and can't figure out why. And thats at 70 on the freeway. At stop and go speeds it cools down to about 210-220. I just changed the oil recently (mobil 1 5w30 synthetic). I do have an oil temp gauge, so the numbers are accurate. Can someone please help? Do I have a major engine failure about to start or something?
Oh and fyi, my water temp is about 180-190 at the same time. Although today it was 215, but it was the first 100 degree summer day this year, so 215 is somewhat normal.
Old Jun 21, 2006 | 11:05 PM
Re: Oil problem?
How are you measuring the coolant temp? I believe the coolant temp gauge on the LS1 cars is not very accurate.
Is your air dam still in place? If its missing, you will encounter high coolant temps at high speeds, which might not show up accurately in the coolant temp gauge.
I've also seen a case where a leaky collector gasket had exhaust blowing directly on the oil filter, causing the oil to heat up.
Old Jun 21, 2006 | 11:25 PM
GoFast908Z's Avatar
Member
Re: Oil problem?
The water temp isn't too high. I know the stock gauge isn't very accurate, but its more accurate than most since its a 98.
I do still have the air dam. And I don't have a collecter gasket as my exhaust is all welded together.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
artic94
Jan 17, 2015 11:19 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
