no power to ecu
I ran into a problem where my ECU no longer comes on with key on. All fuses are good. There must be a signal wire that lets the ecu know when the key is in the on position. Is this wire in a "inline fuse"?
<font face="Verdana, Arial" size="2">Originally posted by sleeperz28:
I ran into a problem where my ECU no longer comes on with key on. </font>
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
- ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
- Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
- Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Also... some info on the car - year, engine, trans, etc - would help us help you....
Fred
94 Formula A3: 381/TH400/N2O
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Fred
Detailed Mod's List
I determined this by checking the power connections on the computer. I have a felpro inline with the factory. I have a constant 12 volts going to both computers. However when I turn the ignition on the computer is not getting the 12 volt signal to prime the fuel pump etc.... If someone can check a terminal, black connector number 30, on there factory computer to see if they get 12 volts with key on that would be great.
1994 Turbocharged Camaro
carguyshu
Jan 22, 2017 11:19 AM
