no power to ecu
Old Jul 21, 2002 | 02:35 PM
sleeperz28's Avatar
Post no power to ecu
I ran into a problem where my ECU no longer comes on with key on. All fuses are good. There must be a signal wire that lets the ecu know when the key is in the on position. Is this wire in a "inline fuse"?
Old Jul 21, 2002 | 02:52 PM
kmook's Avatar
Advanced Tech Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by sleeperz28:
I ran into a problem where my ECU no longer comes on with key on. </font>
How did you determine this? Can you give a little more info? Thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Old Jul 21, 2002 | 04:52 PM
Post
Also... some info on the car - year, engine, trans, etc - would help us help you....
Fred
94 Formula A3: 381/TH400/N2O
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Jul 21, 2002 | 05:59 PM
sleeperz28's Avatar
I determined this by checking the power connections on the computer. I have a felpro inline with the factory. I have a constant 12 volts going to both computers. However when I turn the ignition on the computer is not getting the 12 volt signal to prime the fuel pump etc.... If someone can check a terminal, black connector number 30, on there factory computer to see if they get 12 volts with key on that would be great.
1994 Turbocharged Camaro
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
XtremeLt1
Sep 13, 2002 08:50 PM
