Need help with pistons + dynamic compression
Old Apr 11, 2005 | 08:50 PM
  #16
WS6T3RROR's Avatar
Re: Need help with pistons + dynamic compression
thats a 10cc dish? i mean fill me in on what specks you're using exactly for everything you used as input. looks to me like with a 10cc dish that gives . and about you just about stock compression and an 8.37 dcr. which should probably be just fine on an lt1.
Old Apr 11, 2005 | 10:10 PM
  #17
chy20k1's Avatar
sorry bout that, yeah thats a dish. i dont want to go too crazy with it unless you really think i can get away with more. id like to make as much power with it as i can but i dont want to have problems. oh and 1 more question, how do i determine how high a piston will sit in the bore without actually sticking it in there? is there some formula for that? thanks for your help -dave
Old Apr 12, 2005 | 12:24 AM
  #18
1racerdude's Avatar
The CC's fastfatboy was referring to were 6CC valve reliefs not a dish. You can have Probe make you a 8CC valve relief flat top piston with no dish.2 eyebrow instead of 4,niiicce flat top.
You should be real safe at 8.7 or below.
Some I have talked to claim 9.6 on the street and pump gas??????
I don't want to go there!!!!!
You have to assemble a hole on each corner and measure it to see about your deck height.
Old Apr 12, 2005 | 02:13 AM
  #19
SStrokerAce's Avatar
Chuck talked about a 10.3:1 DCR Pump gas motor! Scary.
Old Apr 12, 2005 | 02:19 AM
  #20
1racerdude's Avatar
I ain't brave enough to go there.Can't afford fuel for the street.
Gas prices keep going up it won't matter.
Old Apr 12, 2005 | 12:23 PM
  #21
Tell me about it.... I'm about to dump Evans in the SS just so I can run 87 octane... Hell it's only 10.1:1 now with a stock cam should have a nice low DCR anyways.
Bret
Old Apr 13, 2005 | 09:16 PM
  #22
chy20k1's Avatar
thanks alot for your help, i appreciate it. -dave
Old Apr 18, 2005 | 03:23 PM
  #23
97Z-M6's Avatar
that cam has 6 degrees overlap according to performance trends cam analyzer.
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
