Minimum Deck Height
Old Oct 6, 2005 | 09:09 PM
93ZM6Tally's Avatar
Minimum Deck Height
Sorry to bring this issue to the top but I'd like some input as I'm going to have to make a decision probably tomorrow. Question is does the LT1 block have enough "meat" to go as small as a 8.975 deck height. Does this leave the deck surface too thin, sealing problems, more susceptable to warping?
Thanks.
Old Oct 6, 2005 | 09:24 PM
Zero_to_69's Avatar
Re: Minimum Deck Height
I think you're chopping off too much?
Isn't the standard height for an LT1 9.025"?
I'm pretty sure the piston sits down about 0.020-0.025".
If you account for the gasket + clearance, I think you're still going to be in trouble?
Old Oct 6, 2005 | 09:32 PM
93ZM6Tally's Avatar
Long story mostly discussed here:
http://web.camaross.com/forums/showthread.php?t=400518
Anyways what I'm looking at is 3.750 stroke, 5.85 rod. 1.250 ch piston = 8.975 zero deck. I may be able to leave it in the hole .010, which would be 8.985.
Old Oct 7, 2005 | 03:15 AM
1racerdude's Avatar
Go with a 6" or 5.7 rod and ya can cut it to 9.0 or 9.005 and have a "0" deck. Ya can also get piston's for the 5.85 rod to do the same thing but they are pricey. Ya can get standard piston's for the 5.7 or 6 rod off the shelf.
Old Oct 7, 2005 | 03:19 AM
1racerdude's Avatar
Another thing ya are asking for real fit problems with the intake if ya go that far.
Let them "cold"weld that block and re machine it.
May 8, 2015 11:30 AM
nosliw
Apr 26, 2015 02:13 PM
cmdeshon
Dec 12, 2014 10:51 PM
