looking for a 4th gen fuel cell
Old Oct 4, 2005 | 10:34 PM
n20ta2's Avatar
I hope this qualifys for this forum, If any one on this site knows where I can find a fuel cell to fit in the rear trunkpocket they would be in here. Im looking for a standard cell 10-12 gallons? as im running a 1st gen sb and its running a conventional fuel system. Thanks.
Old Oct 5, 2005 | 08:06 AM
Re: looking for a 4th gen fuel cell
Personally, I think you would have better luck on "General F-Body Tech and Info".
Old Oct 5, 2005 | 09:32 AM
LT4383's Avatar
Fuel Cell
Old Oct 5, 2005 | 01:06 PM
Z28SORR's Avatar
If you want top-of-the-line? Find one that fits or have one made.
http://www.ioportracing.com/Merchant...tegory_Code=FC
Old Oct 5, 2005 | 02:24 PM
1racerdude's Avatar
Take a measurement of the place where ya want it and look at Summett Racing .
Old Oct 5, 2005 | 07:22 PM
stealthblack's Avatar
Fuel Safe will custom make you one for a second mortgage.
www.frrax.com those cats all run 4th gens with cells.
Old Oct 5, 2005 | 08:06 PM
FASTFATBOY's Avatar
Summit has one that will fit right in that hole, Pops and I measured and considered it, just didnt want the fuel and smell inside the car when street driving. Sump the factory tank, or put a low pressure pump in the stock location.
David
Old Oct 6, 2005 | 12:16 PM
Z28SORR's Avatar
I suppose I should have assumed he was talking about drag racing. When your sports racing and you have 30 gal. of fuel, essentually in the car with you, you wnat the BEST fuel cell you can afford.
Old Oct 6, 2005 | 02:53 PM
n20ta2's Avatar
the reason I want it to fit in the trunk is to be able to run duel 4" diameter tubes over the axle and pan hard bar where the stock tank is now. I already sumped the stock tank but really would like the exhaust over the axle.I am going to weld in a special firewall with a sealed trap door for fuel fill and smell thanks!
Old Oct 6, 2005 | 05:24 PM
FASTFATBOY's Avatar
Why on earth would you need dual 4 inch exhaust? Besides I see no way to run it over the axle on the drivers side anyway unless you use the Dr Gas nascar flat piping, you can make 800 RWHP(or more) with a single 4 inch Mufflex, why would you need 2?
David
Old Oct 6, 2005 | 09:47 PM
n20ta2's Avatar
FASTFATBOY If you take a look at the rear of the f-body with the fuel tank removed there is more then enough room to clear everything, pan hard, rear brace and all.As for why, My new engine combo that is almost finished (700-750hp N/A 1000hp300 shot)is calculated to need 3.5 inch duel exhaust to make max power so im running 3.5 inch exhaust from the custom 2" primary headers to the axle into 3.5 inch borla race mufflers.From there it will expand into 4" mandrell bent tubing over the axle to the factory T/A bumper cut outs. I have already mini tubbed the car and built custom floor boards to accomodate 3.5 inch pipe.
Old Oct 7, 2005 | 06:15 AM
tonylittell's Avatar
wanna sell your sumped tank?
Old Oct 7, 2005 | 07:54 AM
n20ta2's Avatar
TONYLITTLE e-mail me at sprayta@hotmail.com I will sell it,I havent even put fuel in it yet so all I have to do is pull it out its center sumped at its lowest point and has two bungs welded into the sump for duel pumps if you wanted.Its also freshly epoxy painted cast colour.
cmyname1
Feb 19, 2015 08:38 PM
Jul 4, 2005 05:00 PM
BLOWNBIRD
May 28, 2003 01:02 AM
BIGCOWL-IMP
Jul 22, 2002 04:26 PM
