LT1 TFS head issue...bad casting?
Old Jul 26, 2006 | 09:21 AM
  #46
Randy Molkentine's Avatar
Re: LT1 TFS head issue...bad casting?
Got the heads to TFS and it turned out to NOT be an issue with the heads. It was actually a odd issue with the rockers studs not seating correctly in the bosses. They are fixed now and on the way back to Speed Inc. Thanks again to Larry and the crew at Speed Inc for the high level of quality control and to Artie and his crew at TFS for taking the time to examine the parts and figure out a solution. Both TFS and Speed Inc put the customer first and the help from TFS customer service is first class. Both are top notch companies to work with
Old Jul 26, 2006 | 12:12 PM
  #47
Colin91Z's Avatar
Man I'm glad to hear that
Old Jul 26, 2006 | 01:33 PM
  #48
Sean94Z's Avatar
How did they fix them?
Old Jul 26, 2006 | 07:51 PM
  #49
well they didn't fix the heads they modified the studs to work correctly.
Old Jul 27, 2006 | 06:48 PM
  #50
Projectz28's Avatar
Moderator
Hmm, thats odd. But I am glad to hear they helped you out with the problem. You should try to get some more info on teh specific problem here and post up. I am sure many people are curious and it could help someone out at a later date.
BTW, I think I am going to buy a set of TF heads in the near future. Its nice to know they stand behind their work!
Props to both Speed Inc and TF!
Old Jul 27, 2006 | 09:11 PM
  #51
1racerdude's Avatar
If the stud didn't seat correctly it's because the threads were cut in the head at an odd angle.
But no matter ya got it fixed and that's what counts.
Old Jul 28, 2006 | 12:12 AM
  #52
HardcoreRM125's Avatar
What type of studs are you using?
1RacerDude ~ I thought that but didnt say it cause I wasnt 100% sure ... I was sitting here thinking It HAD to be the threads cut wrong.
Old Jul 28, 2006 | 12:18 AM
  #53
MachinistOne's Avatar
The important thing is that they are fixed?.....but like LR said the only thing possible is that the threads were messed up.
They modified the studs? How?
Old Jul 28, 2006 | 12:27 AM
  #54
1racerdude's Avatar
I use shaft rockers,but on other builds I use ARP.
Old Jul 29, 2006 | 08:24 PM
  #55
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I spoke with Trick Flow and was informed that the problem was due to the rocker studs not having a shank under the hex portion to locate the guideplate.
I can't visualize how that would cause the rocker stud to deviate from vertical (in relation to the threads), but they said installing studs with a shank underneath the base hex portion solved the problem. (they also measured all of the cylinder head dimensions which were correct).
Old Jul 29, 2006 | 08:30 PM
  #56
1racerdude's Avatar
I want some of what the TFS rep was taking.He is a frigging idiot,thinking you would believe anything.
Old Aug 1, 2006 | 02:20 AM
  #57
'68LT1camaro's Avatar
Agreed!!
Obviously total bull $hit, but oh well. Of course the guys at Trick Flow can't say, "..........yeah, we screwed up these heads when we were machining the rocker stud bosses.........."
I'm willing to bet that there are more than just this pair out there floating around with the same issues. Sad, but this is the typical quality slide associated with a good company that's purchased by a much larger company. *cough* *cough* Summit Racing *cough* *cough*
Old Aug 4, 2006 | 10:16 AM
  #58
My Iroc Z28's Avatar
Did the package go back together ok? Im curious to what kind of power it put down.
Old Aug 4, 2006 | 01:55 PM
  #59
Colin91Z's Avatar
I'm curious too...so +1
Old Aug 4, 2006 | 07:47 PM
  #60
WS6NIGHTMARE's Avatar
Me +2
