LT1 TFS head issue...bad casting?
Old Jul 10, 2006 | 02:48 PM
  #31
Randy Molkentine's Avatar
Re: LT1 TFS head issue...bad casting?
I still have no updates on the issue as of yet except that the guideplates did not take care of the issue as predicted. I hope TFS has a solution to this.
Old Jul 10, 2006 | 04:27 PM
  #32
Projectz28's Avatar
Moderator
That rotts... I was hoping it would but I just didnt think there was much chance of it being corrected by a guide plate. There isnt much involved with the alignment of rockers. Guideplate control where the rocker tip goes side to side and the rocker position is controlled by the length of the pushrod. If roller tip is not sitting flush on the valve you have one of 3 problems from what I can tell.
first the rockers are or have been machined wrong... you said they tried a different brand also so that is not the problem.
second is the valve stem itself being machined wrong...
third is the rocker stud bores were missaligned when they arer machined. I still find it hard to belive that both heads had the same problem and as of now TFS has not heard of any other problems. (But its not impossible)
Thas all I can think of that would cause this situation. I hope TFS and the shop get the probelm resolved. Let us know what happens..
Old Jul 10, 2006 | 06:31 PM
  #33
I will keep you updated. thanks for the suggestions.
Old Jul 15, 2006 | 04:12 PM
  #34
Speed INC sent the heads back to TFS for inspection. I have 2 pics but don't know how to post them. I will let you know what tfs says
Old Jul 17, 2006 | 10:09 AM
  #35
Colin91Z's Avatar
email them to me and I will host them for you milco25@***.net
Old Jul 17, 2006 | 12:29 PM
  #36
Colin91Z's Avatar
Old Jul 17, 2006 | 03:45 PM
  #37
Thanks for posting those pics.
Old Jul 17, 2006 | 04:36 PM
  #38
Colin91Z's Avatar
No prob man
Old Jul 17, 2006 | 08:30 PM
  #39
sprayedtransam's Avatar
I had the same problem with my AFR heads. We ended up cutting and welding the guideplates so they lined up...
Old Jul 18, 2006 | 03:09 PM
  #40
This does not appear to be related to the guideplates at all. Rocker is slightly leaning even with TFS guideplates.
Old Jul 18, 2006 | 05:42 PM
  #41
Colin91Z's Avatar
Did TFS say when you could expect a response from them?
Old Jul 18, 2006 | 08:25 PM
  #42
Well I took the pics at Speed INC on weds night. They told me they would pull the heads and ship them thurs or fri. Hopefully TFS will have them today or tomorrow. TFS or more specifically Artie seems genuinly concerned about the issue and told me he would "be on them like white on rice" as soon as he recieved them.
Old Jul 19, 2006 | 12:15 AM
  #43
HardcoreRM125's Avatar
What are the chances that your studs are actually bent?
If they are bent, they would twist the trunion part of the rocker sideways, causing the roller tip to sit as yours are.
Can you pick up a set of different studs to try?
It might sound stupid, but everything else has been mentioned. I cant see TFS heads being that bad. I would think its something else defective.
Old Jul 19, 2006 | 02:31 PM
  #44
Well the rockers all are off in one direction. They are brand new arp studs and they had been removed and reinstalled when they tried the different guide plates so if it were the studs odds are they would have seen a change when they reinstalled them as they would not sit exactly the same.
Old Jul 20, 2006 | 12:15 AM
  #45
Man this is crazy ... I was thinking about it all day trying to figure out other things it could be but ...
