LS1 cam bearing install
Old Nov 3, 2005 | 08:37 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
didnt think this was that advanced, but nobody in regular tech can answer it so..
are there any tricks to installing LS1 cam bearings? I am having a "local" machine shop do it that doesnt do many(any?) Ls1s.
Old Nov 3, 2005 | 12:37 PM
NeverEverSatisfied's Avatar
Re: LS1 cam bearing install
Installing a cam bearing isn't a major deal. If they are a real machine shop it should be a cake walk. There are no tricks to installing one. Ever built a rear end? There are some tricks involved with that one...
Old Nov 3, 2005 | 03:14 PM
marshall93z's Avatar
You done it on an LS1 before?
Old Nov 3, 2005 | 03:15 PM
Yea, installing cam bearings in an iron block is straight forward, but I was under the impression there are differences for a LS1/AL block
Old Nov 4, 2005 | 10:24 PM
Yes I have. Have you?
Old Nov 5, 2005 | 08:12 AM
SMOKNZ's Avatar
I had the machine shop do it because my SBC cam bearing installation tool was not the right size for the LS1 bearings, thats the only reason. Had the bearings installed and the cam wouldn't go in. Had a bad set of Federal Mogul bearings (to small of clearance) got a new set and all was fine.
rideordie
Nov 5, 2019 04:52 PM
Sergio
Jan 27, 2016 04:27 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
