pistons for a 396 used with a 355?
Old Nov 3, 2005 | 07:39 PM
chy20k1's Avatar
my friend has a set of brand new srp pistons for a 3.875 stroke, 5.85 rod. hes not using them. can i use them on a 355? i would need really long rods im guessing, i dont know how to do the math to figure it out. any info would help, thanks
Old Nov 3, 2005 | 08:26 PM
SStrokerAce's Avatar
Re: pistons for a 396 used with a 355?
No just a really odd length rod.
You need to know the compression height of the pistons and then you can get a answer pretty easily.
Bret
Old Nov 3, 2005 | 08:53 PM
IllusionalTA's Avatar
compression height is 1.213, does anyone make a rod that length thats not custom? would custom rods be expensive if no one makes the size i'd need? thanks for your help
whoops, didnt switch from my buddies name
Old Nov 3, 2005 | 08:56 PM
markinkc69z's Avatar
Compression height math:
Stroke / 2
Rod Length
Deck height - we'll use 9.00 for a decked small block, 9.025 is blueprint height
Compression distance
3.875 / 2 = 1.9375 + 5.85 = 7.7875
9.000 - 7.7875 = 1.2125 or probably a 1.20 compression distance piston
Okay, now for your 350
3.484 / 2 = 1.742 + 1.20 = 2.94
9.00 - 2.94 = 6.060 rod. Definitely an odd length.
Now you know how to do it for yourself assumng you know stroke length and one other variable.
Depending on the rod you might be able to offset bush the small end, I don't know if it would be worth it for a deal on some pistons though.
Old Nov 3, 2005 | 09:26 PM
chy20k1's Avatar
nice, thanks for your help. i might just buy a crank for a 396, since i might have gone with a new crank and i was definately getting new rods anyways. -dave
Old Nov 3, 2005 | 09:48 PM
Ut oh.. Goin big baby
Old Nov 4, 2005 | 01:57 PM
chy20k1's Avatar
hey, how come none of the cars listed in your sig there can move under there own power???
Old Nov 5, 2005 | 03:45 PM
I have no idea...?
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
