losing weight
Old Jul 24, 2007 | 12:49 PM
Daniel6718's Avatar
losing weight
anyone know a company that makes fiberglass t-tops?
and can you make lexan windows work as power windows? and tint them?
Old Jul 24, 2007 | 01:18 PM
mdacton's Avatar
Glasstek was makin lexan tops at one time. (these are not off the shelf, custom made to order)
You can't make lexan go up and down or tint it. Its for race only, it scratches easy too.
The heaviest pc. of glass is the hatch, windsheild next......BTW lexan is not DOT approved...you can't put it in a street car, and over all I think you are looking at 50 lbs. taken off or less doing all the glass
Old Jul 24, 2007 | 02:19 PM
Daniel6718's Avatar
well vfn sells a scratch resistant lexan....i sent them a mesage...i think the back glass is about 60 pounds by itsef
Old Jul 24, 2007 | 05:54 PM
I bought the roof panel off a guy that did a t-top conversion, with the intent to fit the light weight composite roof panel into the stock t-top frames. But I could never find the required t-top frames. Anyone that damaged the panels when the top flew off the car also managed to wreck the frames along with the glass.
Percy's Speedglass sells replacment sets for the stock 4th Gen glass, including the hatch, but no t-tops.
http://www.percyshp.com/index.php?op...id=3&Itemid=33
They claim there lexan weighs 32#, compared to 96# for the factory glass.
Old Jul 24, 2007 | 09:34 PM
Daniel6718's Avatar
i have a t-top car that im about to crush, the top is perfect only the front end damaged...and ive got t-tops and keys....
so lexan for the whole car would save about 60 pounds?
Old Jul 24, 2007 | 10:21 PM
95custom's Avatar
replacing all the windows with lexan will take off alot more weight than you would think... does anyone know exact weight of total combined glass? im guessing 150+... to the lexan weighing around 50... I would think 100+ pounds would be shed?
Old Jul 25, 2007 | 12:01 AM
Daniel6718's Avatar
i just picked up a hatch and doors from a camaro im parting and they are heavy id say a hatch it about 80 pounds...and doors about 100 each....
dont know how much is glass i think the hatch is about 60 pounds and each side its prolly 10
my car is basically strip only few street miles here and there but i want to still be able to look as factory as possible...and if i can have the lexan roll up and down, didnt think it would be that hard just have to remove the glass and install the lexan, prolly be careful shuting the door as the lexan prolly isnt as stiff....
but i also want to do t-tops i think it can save another 15-20 pounds there
all this and still appear stock
edit, just looked on their site lexan saves 64 pounds for the hatch only!!! woohoo...im kinda scarred to do the front window in this what do yall think?
95chwagon
Oct 16, 2015 12:24 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
karpetcm
Aug 14, 2015 03:02 PM
surreybrad
Aug 10, 2015 09:34 AM
