Piston to valve clearance?
Old Oct 7, 2005 | 03:22 PM
96ta(nick)'s Avatar
Should i be ok running a .605 lift cam and srp -5cc flat top pistons?
Old Oct 7, 2005 | 03:58 PM
cnorton's Avatar
Re: Piston to valve clearance?
NEVER make assumptions about valve-to-piston clearance!! Always check. It is an excellent practice to check all cylinders instead of only one or two for PTV clearance during assembly, particularly if the engine has aftermarket parts.
Old Oct 7, 2005 | 05:31 PM
Victory Racing's Avatar
Piston to valve clearance always needs to checked, no matter how sure you are that you have ample clearance.
dylan1303
Aug 12, 2015 02:00 AM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
WantanLS1
Aug 5, 2002 02:45 PM
