The last rod ratio thread, I swear!
Old Oct 17, 2006 | 10:05 PM
  #31
markinkc69z's Avatar
Re: The last rod ratio thread, I swear!
Ok, I'm gonna bite. How are you going to install Infinity OHC heads on a SBC?
Old Oct 17, 2006 | 10:39 PM
  #32
jerminator96's Avatar
Mwa-ha-ha!
I had a thread about this just before I bought the heads.
The bore centers on the VH45 and VK45 nissan/infinite motors are about .009" off of the SBC. These are the "same" heads they used in the IRL cars.
The main problem as i'm sure you've guessed is the bolt pattern, it's a bit off. And a couple of them actually go into water passages.
The second biggest problem is the timing set.
I'm not the first to do this, though I very well may be the second.
Jeremy
Old Oct 17, 2006 | 11:21 PM
  #33
I'm afraid I'm gonna need video when you're done. : )
Old Oct 18, 2006 | 09:10 AM
  #34
AdioSS's Avatar
West South Central Moderator
http://web.camaross.com/forums/showthread.php?t=463130
Old Oct 18, 2006 | 09:33 AM
  #35
Thanks for looking that one up
Yeah if you want to see one that's already bolted together take a look at Pete Aardema's page. I'm not sure if he has his running yet, I haven't talked to him in a while.
I guess if I tell too many people about this I may have some competition to be #2 on this, huh?
Edit: You'll see video mark, heck I'll stop by your house when I drive across county to show Pete
Old Oct 18, 2006 | 10:55 AM
  #36
Man, I don't think you have to worry about that too much.....
Just let me know and you're welcome over anytime.
Old Oct 18, 2006 | 10:59 AM
  #37
You're probably right, most people aren't crazy enough to attempt something so ridiculous. If it hadn't already been done I probably wouldn't have tried it.
I'll be sure to let you know, though with how long it takes me to get projects done it might be a while.
Old Oct 18, 2006 | 10:43 PM
  #38
HeadDoctor's Avatar
Ok
I went to that Aardema Development site - that guy is using Donovan blocks that don't have the deck drilled for bolt holes - But
He also makes a kool SOHC conversion for fords and Chevy's - Bolts to the regular head. Reminds me of the SOHC heads that Crane had back in the day.
NO pricing though?????????
Denny Schmidt
Old Oct 18, 2006 | 10:55 PM
  #39
I think he told me one time it would be $3000ish for the OHC conversion. Don't quote me though. I don't think he does those anymore though. This is more of a hobby for him and he got tired of doing the OHC kits.
Yeah he used a donovan block but he said if he did it again he wouldn't. I thought maybe he was using the blocks with no water jacket to avoid drilling into open air, but he said they had a full jacket on them. And that's really the main problem with the conversion.
Jeremy
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
pimpss96
Feb 12, 2015 01:28 PM
Bill'sWS6
Aug 5, 2002 01:00 PM
