Jesel belt drives
Old Nov 25, 2007 | 08:46 PM
mdacton's Avatar
Jesel belt drives
Has anyone here ever installed the jesel on a 460 ford?
Jesel does not have instruction for it, seems most 460 people go with a danny bee drive.
I have one to install and looking for any info.....it is a little different than the BBC ones
Old Nov 27, 2007 | 12:54 AM
mdacton's Avatar
Jesel was no damn help.....was supposed to fax me instructions etc. but didn't
I figured it out for the most part..its very similar to the chevy one(lucky we had one here I could compare to and read the instructions)
One pc. is in it that I do not know what it is but pretty sure it is a dry sump mounting bracket but not sure.
The main thing is the 2 front oil plugs in the block need to be installed and the milled flat to the front of the block, Also I had someone tell me to use a meziere water pump b/c it has the best clearance. The center bolt has an adapter on the cam drive with three bolts where the chevy is the exact opposite.....other than that its almost the same set-up.
Pretty nice stuff, this motor also has shaft mount jesels, a sheet metal intake and split dominators so it should be pretty nasty......and its about 16:1
grabbem88
Feb 23, 2015 09:41 PM
Snoman73
Nov 17, 2014 07:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
