Importance of intake tract design.
Old Jul 15, 2004 | 12:42 AM
  #31
1racerdude's Avatar
250ish is no were near 700FWHP.Thats where I need to go.Thanks for the input.
Old Jul 17, 2004 | 01:29 AM
  #32
OneFlyn95z28's Avatar
I am so sorry. Try this one on for a taste.
http://groups.msn.com/WashingtonFBod...to&PhotoID=520
Just my little under construction Engine
Old Jul 17, 2004 | 01:42 AM
  #33
1racerdude's Avatar
Kinda remind's me of mine.Intakes are different,Wilson did mine,but if its built for the engine who cares who built it.
Really nice.When ya gonna make smoke?
Old Aug 2, 2004 | 12:05 AM
  #34
96z's Avatar
96z
Re: Importance of intake tract design.
Originally Posted by OneFlyn95z28
Just some info I have from my last dyno runs with the SLP intake and the two tiny filters. Every since this last Dyno I have been planning on doing some thing different for the filters but I need more testing and the test car is down.
Test Engine. Stock LT1 350CI. slightly modified intake, heads ported to 280+@.600,58MM Billet TB, MBA MAF Ends with stock electronics(Tune calibrated for this), SLP CAI with filters.
This Engine made 395 Corrected 409 actual at the rear wheels through an Automatic and a 12 bolt.
Once above 4,800 RPM the Map started dropping from 101Kpa. It hit a low of 89Kpa along the way and hit 380+ GPS on the MAF reading. THE MAP Drop was not erratic spikes but a fairly smooth drop. Peak HP was at 6,900.
I also have some files on our stock LT1. it only took 250ish GPS of air and the Moroso was fine with just little blipps in the MAP.
Just what I have tested thought I would toss it out there for you to add to your tests.
OneFlyn95z28 sorry I maybe missunderstanding but its late and Im dead tired. So based on your testing is the SLP a restriction as compared to the mentioned moroso based on the drop in Kpa?
Ive thought about doing a CAI swap also. Something along the lines of a 4" elbow from here along with a couple pieces of rubber tubing/fernco from the local plumbing store. My only concern is the air flow transitioning from a smooth 4" elbow entering the engine bay to a squished irractic "ovular" shape as its passes through the tiny space between the radiator and the ABS block. Should 5" tubing maybe be used here to account? Im hoping this along with a 7" or larger K&N filter should outflow the dual 2.5" SLP unit.
Any thoughts?
Old Aug 2, 2004 | 10:43 PM
  #35
96z's Avatar
96z
Anyone?
Old Aug 6, 2004 | 11:31 PM
  #36
96z's Avatar
96z
1racerdude?
OneFlyn95z28?
Old Aug 13, 2004 | 12:51 AM
  #37
PurePonyPounder's Avatar
Highly considering switching over to a Corvette cold air induction system, has anyone documented dyno gains from before after. Since the front fascia of my Callaway has a huge front opening, what better way to capitalize on the design. Do you have to change hoods since the induction goes over the radiator support? Any feeback would be nice. Take care
Johnny
Old Aug 14, 2004 | 12:17 PM
  #38
96z's Avatar
96z
There was a guy who did the same thing with the corvette cai. Take a look at some of the pics Jkren posted earlier in the thread. This is that guys CAI.
Old Aug 15, 2004 | 10:58 AM
  #39
Yeah I saw the pics but I didn't get the user board name. Considering purchasing an aftermarket C5 CAI but skeptical on whether if the hood will close. (I think not) Can anyone help me?
Johnny
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
May 15, 2015 10:43 AM
maybe2fast
Mar 26, 2015 08:34 AM
