I Need Help Now!
I Need Help Now!
im buildin a 383 and tha machine shop needs a piston to bore out the block(i guess to make sure they fit perfict) now im not buyin a whole rotating assm.(trin to save a few bucks) anyways, i found these at summit racing . will they work wit a 3.750 stroke and 5.7 in. rod? im just trin to aviod a costly mistake.
http://store.summitracing.com/partde...w=1&N=700+150+
Those are a .060 over piston for a 383 you need a .030. Why reuse the stock rods, you can p/u eagle or scat stuff for less then $200. Plus now you have to pay to get everything balanced vs buying a balanced kit.
Rich
No, the stock rods will not handle 800 HP. With that large a shot (basically what I am running) you need a piston specifically made for nitrous, and rods a lot beefier that what you get for $200. And don't forget a high quality crank for your 388.
Might have been a good idea to mention the 300-shot in the original post.
Sort of a contradiction, on an engine that's supposed to support 800HP.
I think you need to step back, hold off on the build, and do a little research. It could save you thousands in the future. Ask a few questions around here, learn who to listen to, read a few books, and go from there.
