How much HP is lost with the Mcleod Street Twin???
Originally posted by Eric Bryant
A light flywheel is of great benefit in road racing because you're downshifting in addition to upshifting. Not many folks rev-match when dragracing, so the time that it'd take for the revs to drop with a heavy flywheel isn't important.
Conversely, when drag racing you want to hold the RPM's not only on initial lauch, but at each shift point. The heavier flywheel/clutch combos assist in that effort by, as several folks have pointed out, storing energy that can cushion the RPM drop both the at the initial launch and again at each shift point.
One of the quickest ways to drop ET's in an otherwise stock vehicle is adding in a heavier flywheel/clutch combo. It used to be a tech inspection point in the stock classes in NHRA but it's been awhile since I've raced so I don't know if it still is.
Bill
brothaslide
Jan 9, 2016 12:11 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
ricks95TA
Jul 23, 2015 12:59 AM
Louey
Pacific
Jul 21, 2015 10:06 PM
