How much hp can these flow numbers support?
Old Sep 27, 2007 | 05:43 PM
jakesz28's Avatar
Not for sure if this is the right forum but. How much hp can these flow numbers support? This is out of a older set of Brodix -10 heads.
These are flowed at 28 on a 4.030 bore
int exh lift
195.4 133.5 .300 at 27.97
241.7 162.1 .400 at 27.96
264.5 183.6 .500 at 27.95
274.3 196 .600
283 203 .700
The exhaust seems good compared to the intake.
This will be on a 383 with 12 to 1 comp, a single plane intake, and a solid roller.
Old Sep 27, 2007 | 06:14 PM
1racerdude's Avatar
Roughly 580FWHP everything else being correct.
Old Sep 27, 2007 | 07:12 PM
ulakovic22's Avatar
I was always told a good rule of thumb to ballpark it is 2hp/cfm.
Old Sep 28, 2007 | 08:11 AM
Stephen 87 IROC's Avatar
I'd also go with around 580 hp max.
Old Sep 28, 2007 | 10:21 AM
rskrause's Avatar
Moderator
It's a good rule of thumb, but that caveat of "everything else being correct" is a big one. I mean, a 400hp STOCK head LT1 would be ~2hp/CFM. That is perhaps do able, but not easy.
Rich
DirtyDaveW
Dec 1, 2016 05:37 PM
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
