How to get installed height of these springs as high a possible
Old Feb 23, 2003 | 11:16 PM
LTOne4Fun's Avatar
Whats the highest you could install the Comp 943s to? Stock height is around 1.78 so what combination of valve length, +.050 retainers or possibly lowering the spring seat can I use to raise the installed height? Can I drop the seat that mch at all?
Old Feb 23, 2003 | 11:32 PM
SStrokerAce's Avatar
Probably can't take the seat down any more. You can get the valves long enough to get it where you want it
The 943's still have 212 lbs on the seat @ 1.950, I would run them @ 1.900, which means a .100 longer valve, +.050 lock/reatainer and some shims to get it exact.
Bret
Old Feb 24, 2003 | 05:47 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
what kinda pressure do you need? like he said.. with +.100 valves and .050 locks you can get 1.950 pretty easy...
Old Feb 24, 2003 | 07:51 PM
LTOne4Fun's Avatar
I dont think he will need as much spring pressure as you normally would with a solid its a small one about 225 degrees duration. Trying to get all it needs but not extra wasted spring pressure
Old Feb 24, 2003 | 10:27 PM
I woul still start out at 200-210 on the seat(1.950ish). they will lose 20lbs quickly from use, and I bet your cam would be fine with 180(what did the grinder say?)
I would say 220 at most(starting)
Old Feb 24, 2003 | 11:52 PM
LTOne4Fun's Avatar
It hasnt been ground yet, he is awaiting the final outcome on his heads before the cam is ordered
Noenav
Mar 1, 2019 07:38 AM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
Jan 23, 2015 01:13 PM
cmdeshon
Dec 12, 2014 10:51 PM
