How to convert cam specs from .020 to .050
Old May 14, 2005 | 02:24 PM
MichiganSkip's Avatar
How do you convert the timing specs of a cam from .020 to .050
Thanks in Advance
Skip
Old May 14, 2005 | 03:01 PM
rskrause's Avatar
Moderator
Re: How to convert cam specs from .020 to .050
You can't.
Rich
Old May 14, 2005 | 03:04 PM
Mindgame's Avatar
Hmm, that would be real tough to do. You could plot an approximation with enough data points but it's still just an educated guess.
It's tough because it depends on the lobe's acceleration rate. Different types of lobes have different acceleration rates... ie, solid flat tappet vs solid roller and/or max-area hydraulic vs you-name-it... They're all different, even among same type cams from different companies.
Have you thought about calling the cam company and asking for the information? Would probably be your best bet.
-Mindgame
Old May 14, 2005 | 04:39 PM
-Mindgame
I see what you're saying. I didn't even think to call Comp Cams and ask them. Thanks for the heads up!!! DD2K and some of my DFI software ask for that info on a .050 measurement and the card I have shows a duration taken at .020 and the valve timing #'s are at .020
Old May 16, 2005 | 08:48 PM
97Z-M6's Avatar
ok how do you find the ramp rates.
so to but in on the thread.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
