Horrible problem I've been fighting for months please help
Old Feb 11, 2004 | 01:27 PM
  #16
will62085's Avatar
would it be possible that the supercharger is stalling? ie. too much boost, too small of a blower?
just a thought
Old Feb 11, 2004 | 03:50 PM
  #17
GreenbeanZ28's Avatar
My car is doing something similar, but I dont have a supercharger. Cuts out at 6200-6300 and drops nearly 100 rwhp. Havent gotten to log anything yet, but so far nothing has helped.
http://www.advancedinduction.com/Dyn...ynoProbSAE.jpg
Old Feb 11, 2004 | 10:08 PM
  #18
Alvin@pcmforless.com's Avatar
the boost stays at 9psi the whole time so its impossible for the blower to be sucked out
I can't change pulley sizes on the fly but i'm sure your right and that would affect it.. BUT the problem is I need something that would fire threw the charge.. not punk out with a less boost
i'm convinced its blowout but i wont' be able to tell for sure until i have a bit of time on my hands.
Old Feb 11, 2004 | 10:42 PM
  #19
will62085's Avatar
if it was blowout, why does the power increase after a certian rpm? mabye im missing something
and true, the boost is remaining constant, but the speed on the impellers is still increasing with rpm, and after a certain rpm with enough pressure on the blades of the impeller, anything will stall. a high degree pitch prop on a plane can make more thrust at a lower rpm that at a higher rpm...i dunno, this is just a theory im not that familiar with blowers...
Old Feb 11, 2004 | 11:30 PM
  #20
because cylindar pressure comes back down. especially with the camshaft i'm using.
If the compressor was stalling than the output would be reduced and the boost would fall
Old Feb 12, 2004 | 12:13 AM
  #21
will62085's Avatar
ok, i get it, i feel dumb
Old Feb 12, 2004 | 03:45 AM
  #22
lt1form's Avatar
I just got a job at Summit, and we had a MSD tech guy give us a seminar today.
Well I believe its got to be spark blowout, which MSD coil are you running? some coils are rated at 80 to 200 milliamps. Even their big honkin Blaster SS is only 300 milliamps.
Since you have the MSD 6 series try the MSD 8253 coil (Blaster HVC II) maybe it will help?? It is rated at 450 milliamps.
If not you'll have to get a 7 series ignition, but then you could run the HVC II coil, just think 2000 milliamps, whoo whoo!
TWO (2) full amps!!
Old Feb 12, 2004 | 09:09 AM
  #23
I'll think i'll do that LTCC swap before that.
I've had problems with ignition boxes in the past
Old Feb 12, 2004 | 12:41 PM
  #24
marshall93z's Avatar
seems hard to believe that only 9 psi would be the most you could do without blowout. there are plenty of people that run more boost than that with no problems.
did you try gapping your plugs down more yet. i remember you saying something about .025-8 or something like that.
Old Feb 12, 2004 | 01:47 PM
  #25
the difference is I make 9psi at peak torque.
Nope sure haven't don't have a 3/4 wrench on me and nobody here seems to either. So i got to wait until i go home again.
Old Feb 13, 2004 | 07:40 PM
  #26
heck what do you know.. Found a 19mm in my tool kit.
regapped all the plugs down to .025 and its still doing it. No change.. just drives worse around town.
Old Feb 13, 2004 | 10:00 PM
  #27
JSK333's Avatar
If it's been doing this with different power adders, engine combos... have you checked for timing chain slop? Maybe the timing is being wacked at the higher RPMs if the chain is loose.
Old Feb 13, 2004 | 10:02 PM
  #28
2 completely different motors and timing chains
Old Feb 13, 2004 | 10:03 PM
  #29
JSK333's Avatar
Tried changing the PCM tune?
Old Feb 13, 2004 | 11:04 PM
  #30
you can say that..
I do tuning for a living
2 bar, 1 bar, nitrous all the same no runny above 4,000rpm and below 5,000
