help with walbro 255lph INLINE pump!
Old Aug 22, 2002 | 07:18 PM
94REDSTALLIONZ's Avatar
Post help with walbro 255lph INLINE pump!
ok i got my pump and mounting brackets today...but no instructions came with it...can anyone post an install link or something?there is like 4 fuel lines coming out of my gas tank...wich one do i put it in?..i need a diagram of some sort lol...any help would be greatly appreaciated.
carter
'2000 onyx z28
stock heads,intake,bottom end...and all motor! 11.63@116.74 1.54 60'.....on nx 125 wet..11.01@126 with a slipping tranny and some traction issues...new times soon...my car can be seen here!!http://www.horsepowerstore.com/page.asp?id=19
Old Aug 22, 2002 | 11:23 PM
89ProchargedROC's Avatar
Post
It is fairly simple really, one side is the suction side and one is the feed side
you want to put your 3/8" feed line on the suction side either before or after the stock fuel filter....
Get a good 30amp relay and hook it up. One side is negative, other side is positive. Hook those up to the ground and 12+ on the relay.
Then the other 12+ wire runs up to a power source (alternator best place, run a 8 or 10 gauge wire for best power) and the other wire tees into your stock harness that turns on the intank pump, that way they both turn on at the same time
Old Aug 22, 2002 | 11:40 PM
Post
how many prongs should the relay be?and do you mean a 3 or 4 prong relay..or one of those ad a fuse kits with the little inline fuse?a diagram would still help me a little lol if anyone has some link or something...but thank you very much man..you were most helpfull.
'2000 onyx z28
Old Aug 22, 2002 | 11:42 PM
kmook's Avatar
Advanced Tech Moderator
Post
This really should be posted in LS1 Tech since its not really 'Advanced'.
I'll move it there now for you.
Thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
New Project Underway :0
Apr 24, 2015 01:03 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
transamtom
Sep 16, 2002 05:47 AM
TSIracer
Nov 12, 2001 12:21 AM
