Help me figure compression so I can tell Lloyd what to mill them to!
Old Apr 17, 2003 | 05:05 PM
  #16
Speeds8erM-1's Avatar
Thanks so much for your help! My head is about to explode over this d@mn car. I played with that calculator a little bit and came up with different numbers but I didnt mess with it that much.
Old Apr 17, 2003 | 05:07 PM
  #17
How did you figure deck height? I am not sure how to figure it?
Old Apr 17, 2003 | 05:08 PM
  #18
Mindgame's Avatar
No problemo. Just don't have an aneurism!
Let us know how everything turns out. If you want to know the exact numbers I plugged in let me know. I checked em 3 times just to make sure though so you should be set.
edit: Ok the deck height is the distance from the deck of the block (which is 9.025" from the centerline of the crank) to the top of the piston at top dead center.
You take the stroke and divide it by 2 (3.48/2) + the rod length + the pisto's compression height. You should come up with 9.003.
9.025 - 9.003 = .022. So the piston is down the bore .022 at TDC and .022 is your deck height.
HTH
-Mindgame
Old Apr 18, 2003 | 01:21 AM
  #19
We checked it again tonight, this time with the right tool to get an exact number, the pistons are .029 in the hole. So, whats the compression looking like now?
Old Apr 18, 2003 | 03:52 PM
  #20
If my pistons are .029 in the hole, is that my deck height?
Old Apr 18, 2003 | 06:51 PM
  #21
Mindgame's Avatar
Ok, .029..... using the same calculator I get 11.26:1.
-Mindgame
Old Apr 19, 2003 | 01:34 AM
  #22
D@mn it! What would the Impalla Gaskets put it at? Sorry for all the questions, I am a compression idiot.
Old Apr 19, 2003 | 01:51 AM
  #23
Mindgame's Avatar
I get 11.59:1.
It's ok to be ignorant of something but give yourself maybe 5 minutes of study and you'll have the whole concept down. Or you could just plug the numbers in.
-Mindgame
Formula Steve
Sep 19, 2023 08:31 AM
marlar98
Sep 12, 2018 07:18 AM
Formula Steve
Sep 19, 2015 08:48 PM
bunker
Aug 21, 2015 10:21 AM
karpetcm
Aug 14, 2015 03:02 PM
