Headers for bigblock in 4th gen
Old Sep 8, 2004 | 06:20 PM
Roadracin396's Avatar
Are there any headers presently made for bigblock to work in a 4th gen.
Also what intake should i go with not sure about cowl clearence. I know i may have to cut the cowl or remove it to clear the carb. And can you run a belt drive distributor so you wont have to pull the engine if you have problems with the distributor in the future
Old Sep 8, 2004 | 08:22 PM
Stephen 87 IROC's Avatar
Re: Headers for bigblock in 4th gen
Nobody makes a direct engine swap header. From what I've read, you can use Hooker headers #2455. They're not an exact fit and some modifications will be required to make them work but that's your best choice unless you want to fab up a set of custom headers for 4 times the cost plus all the headaches.
Old Sep 9, 2004 | 02:07 AM
Steve in Seattle's Avatar
you'll need to swap out the fuel pump and fuel lines as well.
You'll definitely need a cowl to clear the hood on any set up... on a big block you might need even more.
Don't know about the distributor... sorry.
Sounds like you might wanta check into getting a set of custom headers done up... but that won't be cheap. This is definitely not a "bolt in" upgrade though so that's to be expected I guess.
What kind of rearend/tranny are you going with? what are your hp/ET goals?
HOFFICER
Apr 6, 2020 10:36 AM
R@mpage
Apr 20, 2015 10:02 AM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
