Gen1/Gen2 question
Old Feb 12, 2003 | 02:45 PM
ryan2's Avatar
Gen1 SBC conversion (again)
Ok, what I want is a stock looking (for the most part) 434+ cid motor.
So, what are my options here? Perferably, I'd like to use a Dart Little M block and aftermarket heads, maybe ported Brodix Track1?
So, how hard would it really be to get one started up? A standard dist. would fit right? How much would I have to hack the cowl to make it work?
Can I use a CSI/Meziere EWP with the stock heater, etc.?
Has anyone used a TPIS Mini-Ram on a 434+ and LTx-style TB? I want to keep a stock hood and keep it looking almost stock
Also, we do emissions here (just a visual and sniffer for OBD1 cars). I will hopefully be using DFI. So, could I pass with a non-radical solid roller in a 434 with cats if I tune it right?
RDJ
Old Feb 13, 2003 | 02:39 PM
ryan2's Avatar
TTT
Edited post with better questions....TTT
Old Feb 13, 2003 | 06:12 PM
z28kid93's Avatar
What's up?
I'm in the process of working out pretty much the same things you are for my '94 Camaro. If you are going with a Gen1, i'd look at the MSD low profile w/ crab type cap to clear the cowl. that should fit and with only a little bit of cutting possibly. there are a few differences though since i'll be running a carb setup(full race).
As for your tuning, well I guess anything would be possible. The DFI would allow you to run an "emmissions only" program to help you pass, but i would only run it for the emmissions test so as not to hurt the motor. but then again, you may not need it.
Hope this helps a bit.
Chris
Old Feb 14, 2003 | 08:11 AM
strokedTA's Avatar
From: Where people don't discriminate about your induction system.
I've had a Gen1 in my car for a few years now.
406 Dart block, carb.
Dave Brown http://strokedta.vettextc.net/track/Dave-3.jpg
Old Feb 14, 2003 | 12:49 PM
z28kid93's Avatar
Hey Dave....
Nice car!!! Can you do me a favor? Can you post up some pics or links so that I can see how far back the carb ends up by the cowl? Thanks a ton!!
Chris
Old Feb 14, 2003 | 11:30 PM
strokedTA's Avatar
Chris, I don't have any real good pics. I just don't take that many. I have no use for them and I'm not one to flash my stuff all around like some people that have to take pics of every little thing. If you email me I can send you a few of when it was just getting done. Maybe those will help?
You WILL have to cut the cowl some, more if you want an air breather on there, and you WILL need a cowl hood of some type.
Dave
Old Feb 17, 2003 | 05:41 PM
z28kid93's Avatar
Dave...
you got mail!
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
